Making 02' F350 Into Rollback tow truck? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-22-2010, 07:08 AM Thread Starter
I have an 02 F350 superduty that I want to make into a rollback tow truck. Does anyone know what problems I would have doing this? I already have a rollback bed with a wheel lift off an 88' f350. What concerns me is that I have never seen 1999-2006 f350 superduty made into a rollback tow truck. I have seen these years with regular tow truck with wheel lifts but never a rollback. Basically I'm asking if anyone knows if there is some reason I shouldn't do this? Thanks Nick
zukpower06 is offline
post #2 of 5 (permalink) Old 11-22-2010, 11:10 PM
whitejohn's Avatar
be careful with your gvws i kno a guy who took a 3500 dodge and put a dump box on it and could only carry a few hundred pounds legally before he was over weight
whitejohn is offline
post #3 of 5 (permalink) Old 11-23-2010, 12:12 AM
TousleyParts's Avatar
I have seen rollbacks of this body style, but only on F450s and F550s. I don't think you could legally carry any decent amount of weight with a F350.
Also, check the frame width between the two frames. Most chassis cabs will have different frame widths than a pickup.
TousleyParts is offline
post #4 of 5 (permalink) Old 11-23-2010, 10:51 AM
LTFFNREMTP's Avatar
Before you get carried away make sure your transmission has a PTO provision, otherwise you'll have no way to run anything. Personally, I think a 350 is too small to carry much more than a compact or small car as a roll back and still drive good. Not to mention, is your wheel base long enough to accommodate a 17' or so bed? Anything less than 17-18' is pretty much useless. Your bed would have to be aluminum to save a gang of weight as well. But, there are a GANG of F350 roll backs out there - quite a few of which shouldn't be.
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
LTFFNREMTP is offline
post #5 of 5 (permalink) Old 11-23-2010, 11:00 AM
hugestroke's Avatar
you dont have to have a pto they make a belt driven pto pump you omunt under the hood just do some mesuring the bed and brace every thang up your going to have to stretch the frame for sure.
2000 f 250 7.3 liter auto. Started as a xlt truck has been up graded to a lariat. 8 inch fabetek lift. 20 inch eagle alloys painted black. 41/14.50/20 super swamper irocks.05 head lights with 10,000k hid's. Turbo back 4 inch into two 6 inch stacks under bumper. edge juice with attitude. k&n cold air. ready for dp and ingectors.
hugestroke is offline
