mileage comparison between 235/85 and 265/75 tires - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 08-04-2006, 06:02 PM Thread Starter
My Photos: (12)
Has anyone tried a set of the 235/85 16 tires to see if you would gain significant fuel mileage over the 265's?
2003 F250CC shorty Lariat 7.3 PSD, Jody Tipton Flash, Autometer boost and EGT gauges, Nordskog trans temp, fuel press, voltmeter. Banks exhaust, Hughes TC (replaced dead PI failed converter don't wast your money on the purple converter), Transgo tugger kit, Hyd oil filter on trans return line, custom HD y-pipe boot clamps, BW Patriot hitch, PML pans, Manual TC lock and indicator EBV delete the right way, bellowed Up-pipes. and too much others stuff -- 89 F250 7.3 IDI 4X4 tuff truck--Some KTM dirtbikes, 2001 Jetta TDI with 424,000 miles still running strong (hope this Ford lasts that long, 135,000 now).
dieseldrive is offline
post #2 of 6 (permalink) Old 08-04-2006, 09:03 PM
Re: mileage comparison between 235/85 and 265/75 tires
I swaped from 215's to 238's and the speedo didnt change, but then you wouldnt see any differance untill you have the speedo programed for the tires. Im sure Im going much further per tank but cant tell.
alabamabuddog is offline
post #3 of 6 (permalink) Old 08-04-2006, 09:42 PM
I got the 235/85 16 in michelin, Right from the get go. Bought vehicle used & never drove on highway before. I turn about 2000 rpm at 70ish mph. So far the best milage is only about 13.5 (hand calculated) . I just ordered jody's chip, & hope I'll make a difference. Disapointed so far.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
post #4 of 6 (permalink) Old 08-05-2006, 09:57 AM
SmokeyWren's Avatar
My Photos: (45)
235/85s and 265/75s are exactly the same diameter, with exactly the same tire revs/mile. So theoretically, the only cause for a difference in fuel mileage would be the very small increase in drag of the slightly bigger tire patch and the small incease in aero drag of the wider profile of the 265s.
There should definitely be a slight difference in fuel mileage, but with the same tread pattern it is probably not measureable in less than several thousand miles with each tire.
I'm now running Michelin XPS 235/85R16 Ribs (summer highway tread) - replaced LT285/75R16 AT. With calibrated speedo, there is no measureable difference in towing MPG, but there is about one MPG improvement in unloaded MPG.
SmokeyWren is offline
post #5 of 6 (permalink) Old 08-05-2006, 11:48 AM
I've done exactly that. From 265/75 16 Steeltex to 235/85 16 Michilin LTX. Fuel economy average was actually better on the last 20k miles of the 265 than the first 20k miles have been on the 235. Probably had a few more highway miles on the 265s. Really there is no difference.
2002 F250 Crew Cab, 2WD, Auto, 100k miles, 80hp Econo PCM, ISSPro Gauges, Ford AIS, Walker BTM.
ramblin_wreck is offline
post #6 of 6 (permalink) Old 08-05-2006, 11:51 AM
468LC's Avatar
What about rotational mass in stop and go driving?
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 100k miles.
Wix coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT. Sinister EGR delete, EGR cooler delete, up pipe. Looney Tune via SCT X4. S&B Intake.
Mag-Hytec transmission pan, 08 diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
2012 Heartland 5th wheel. 36' @ 12k pounds.
468LC is offline
