Military Tires - Diesel Forum - TheDieselStop.com
Old 10-07-2008, 09:38 PM   #1 (permalink)
Blacklung's Avatar
Military Tires
Hi everyone. I'm new to this site but have some questions about running military tires on a superduty. I just picked up a set of 46" michelins and was wondering if anyone else has ever run a set of these on there truck. They will be going on my truck pictured below. Right now, i'm running 44" super swampers on a 12" lift. But my big question is: if any of you have run 46" military tires, what type/style of rim did you mount them on. I know they will fit on a 20x10" rim, but the bead is so big i was just wondering if they will fit on any standard rim. Any help is appreciated. Thanks.
P.S. Here is my truck i'm hoping to mount them on:
Blacklung is offline
Old 10-08-2008, 09:40 AM   #2 (permalink)
stevedunham's Avatar
My Photos: (6)
I looked into the Michelin Military Truck tires for my Bronco Rockcrawler at one point but ended up passing on them due to 2 issues... They are way heavy and they are hard ( at the time ) to find wheels for...
** SMD '04 F250 SD King Ranch delivered 8/19/04 **
28% Tint, Leer 100XL Cap, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, MBRP Duals, 4.56's w/ F&R ARB's, original motor blown @ 31,000..! Dynatrac Dana 60 35 spline stubs kit, PIAA 520 ATPs, Xenon HID's, Powerslot Cryos/Hawk LTS, SCT X3, blown Turbo replaced with II 60FORDHY, 58V FICM PICS
stevedunham is offline
Old 10-08-2008, 03:47 PM   #3 (permalink)
Blacklung's Avatar
Ya, i was a little bit concerned with the weight, but they are not too much heavier than the swampers on steel beadlocks. I found a pic of a duramax with 46" michelins on 20x10 Kmc Rockstars, but I don't know if they had to be custom made to hold the bead of the tires, since it's about 1-2" thick.
Old 10-08-2008, 11:18 PM   #4 (permalink)
C. A. Guy's Avatar
Yep those tires will snap the ball joints right out of that ffront housing. That's why I'm not running them on mine. Plus you need some serious gears to move the truck after that much tire size change
C. A. Guy is offline
Old 10-08-2008, 11:18 PM   #5 (permalink)
C. A. Guy's Avatar
And yes they will fit standard rims
Old 10-09-2008, 03:22 PM   #6 (permalink)
Blacklung's Avatar
My trucks' held up pretty good so far running the 44" Swampers. The only problem I've had so far is a few broken wheel studs. And as far as gearing goes, I think my 4.88s can handle it.
Old 03-21-2010, 10:42 PM   #7 (permalink)
Layney's Avatar
Yep, they will run on standard alloys .... mine are on 20x9 actually ... Just regear, and build the truck right, you should be ok ....
-Josh
Layney is offline
