Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-03-2009, 04:26 PM   #1 (permalink)
modless tank capacity
havnt done any mods on my fuel tank at all... when i fill up i just let it go till it clicks off then im done i dont try to squeeze anything more into the tank... how many gallons am i probably getting in there?
17 years old tryin to build my first diesel machine...
2000 F250 red ext cab 7.3L PSD. 4x4 off road pkg. 6 speed manual. diy 6637 air intake w/ afe intake tube. 4" turbo back magnaflow straight pipe. 5" afe tip. DP Tuner F5 stock, 60t, 80e, 100p, 140a. 3 pos pillar pod autometer phantom pyro/boost gauges and DP control. extang trifecta tonneau. 34 in toyo open country m/t. bull bar with 2 6 in. KC daylighters.
Pray for our country.
1928 Ford Model A stake truck. 1931 Ford Model AA dually flat bed.
achowell is offline
Old 01-03-2009, 04:56 PM   #2 (permalink)
Don't know about the short beds with the 29gal tank, but mine (38gal tank) will hold another 4 gallons after the nozzle shuts off and the foam goes away. I have no idea how much more the fill tube will hold (beyond the 38gal tank), probably a gallon or so.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
Old 01-03-2009, 05:26 PM   #3 (permalink)
i hav the 38 gal.
achowell is offline
Old 01-03-2009, 07:23 PM   #4 (permalink)
On my short bed with the 29 gallon tank I can get anywhere from 3-5 more gallons in the tank. It takes a while though. Would like to do the harpoon mod, but it is way to cold outside right now. Also I don't have too many friends that are mechanically inclined to help me drop the tank.
2004 F-250 PSD CC SB FX4
Pace Edwards Jackrabbit cover
IPF 968's
4 inch mbrp 409ss cat-back
alexjeep is offline
Old 01-04-2009, 02:52 AM   #5 (permalink)
use a floor jack and a couple of ratchet tow straps.
achowell is offline
Old 01-04-2009, 11:56 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (42)
On April 2, 2002 I came in on fumes. My truck took 42.8 gallons to fill it up through the foam to have liquid diesel at the cap.
At most truck stops, after mine shuts off with the automatic fuel filler shutoff, I can dribble in another 4.5 to 5 gallons. 42.8 minus 5 gallons is 37.8. Therefore, if I don't dribble in that last 5 gallons or so, then my 38-gallon tank holds at least 37.8 gallons. But if I take another 10 minutes to fill it to the cap, then it holds at least 42.8 gallons.
Since my engine was still running good when I stopped to fill up, I don't really know how much longer it would have run. But not much, I'm sure. So WAG 2/10ths of a gallon, and I'll say mine holds 38 gallons if I don't add more after the automatic shutoff clicks off.
But 43 gallons if I do my normal fillup with liquid diesel at the cap.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is offline
Old 01-06-2009, 01:40 PM   #7 (permalink)
doczenith1's Avatar
My Photos: (11)
I also did some experimenting back in 2002. My results are for a gasser but should be similar.
I loaded a 5 gallon gas can (with 5 gal of gas) in the back of the truck and headed out for a weekend trip. On my way home I purposely ran out of gas. After pouring the 5 gallons of gas into my tank I drove to the nearest gas station which was only two miles away, thus not using much gas after running out. I made sure to fill the 5 gallon gas can to the same level as it was before filling my truck on the side of the road. Here are the results.
8794 - low fuel light comes on, overhead display (OHD) says 27 miles to empty.
8813 - OHD says 10 miles to empty.
8832 - OHD says 0 miles to empty. (wow 10 miles = 19 miles…)
8866 - ran out of gas, OHD says 16.1 mpg. (70 mph…must have been a tailwind!!)
Now, I reset the OHD when the low fuel light came on, to get the correct gas mileage for the last few gallons. This will be used to calculate the number of gallons left in the tank when the low fuel light comes on. You will notice the 'OHD - miles to empty' gets a bit confused when the fuel level gets low. From my calculations, there is about 4.5 gallons in the tank when the low fuel light comes on based on 16 mpg. I've found that the OHD runs about .5 mpg high, so the 4.5 gallons is conservative.
It took 29.3 gallons to fill the gas can and the truck. This is to the point where the pump automatically shut off. The most I've trickled in after the pump shut off is about 4 gallons.
2002 F250SD Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. - added Silver Stars and SUVLights Harness, Pioneer Premier FH-P800BT deck, PRS-X220 amp and TS-W1240C sub, Pioneer GEX-P910XM XM Satellite Tuner, K&N FIPK, FM50 Delta Flow, 285/75R16 Bridgestone Dueler A/T REVO's. - 12/01
2003 Mustang Cobra, black convertible. - 6/07
doczenith1 is offline
