Multi function switch gone loopy
Hey guys, hope someone can shed some light on my problem. I have a 99 f-350 super duty 7.3 diesel automatic. Directionals started acting up (some times they blink, sometimes they don't, sometimes you can get them to work by lightly applying presure on the lever etc. ) All the parking lights work, flashers work, brake lights work, high beam works wipers and fluid button all work. I checked the fuses, checked the bulbs, replaced flasher relay, still nothing helped. So I figured it was the multi function switch. Picked one up, installed it and when I turned the key on, the fluid started spraying, the wipers where on high, the directionals still did not work and all the settings are ass backwards. Low is high, intermitent is low, fluid sprays on a couple of the settings. Figured it was a bad multifunction switch, so I was able to exchange it for another and when I installed it it did the same thing. I put the old multi function switch back in and I am back to where I started.
Any suggestions would be helpfull.
