Multi Function Switch Removal? - Diesel Forum - TheDieselStop.com
Old 06-06-2006, 02:55 PM   #1 (permalink)
What is the procedure to remove the multifunction switch? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Y2K F350 Lariat, Born on 01-00, CC, 4x4, DRW, LB, White, 6spd Short Shift, Hutched, Pre-Pump, HX, Pooned, DI Fuel Reg, GPT38R BB, EBPV Delete, Swamps 200cc Single Shot Hybrids, 4" Exaust Straight Piped, Bilstien shocks, Jordan Brake Controller, B&W Flip Hitch, Timbren Load Springs on rear, Zoodad, Donaldson Filter, TS Performance stock-high-idle-60-80-100-140, Pillar IssPro Gauges,
Riley coolant filter, Evans Coolant, 203T-Stat, SP Performance EBP sensor, CCV Mod to atmosphere, MileMarker hubs, South Bend Con OFE, Ranchhand front bumper, Hillsboro aluminum flatbed ...!!!
termite is offline   Reply With Quote
Old 06-06-2006, 03:24 PM   #2 (permalink)
FINE69's Avatar
Re: Multi Function Switch Removal?
Whats a multi function switch? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2009 F350 CCLB Larry-at, 6.4, all the toys....
http://community.webshots.com/user/FineFord
FINE69 is offline   Reply With Quote
Old 06-06-2006, 06:08 PM   #3 (permalink)
The multi-function switch is the blinker/hi-beams/windshield wiper lever on the left side of the steering column.
Sorry but I don't know the procedure for removal. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
My Truck Pics
NorCal Powerstrokes
ryaneverk2 is offline   Reply With Quote
Old 06-06-2006, 08:43 PM   #4 (permalink)
Banned
Three screws from the bottom of the steering column garnish to remove the lower half... remove the ignition lock cylinder to remove the top half.... Two TorX head screws to remove the MF switch and then unplug the connectors - be very careful not to break the connector shells.
GrampyJim is offline   Reply With Quote
