Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 07-22-2008, 05:59 PM   #1 (permalink)
My AC smells nasty (2007)
I have the mildew odor coming out of the vents when you first turn on the AC. The smell goes away after about 3-4 minutes, but it's pretty nasty at first. Is there an easy fix for this? Please let me know. Thank you.
2007 F250 Lariat, CC, 4WD, Chrome & 20" Wheel option, 2008 Mirrors, MBRP, Isspro Pyro, XM w/PIE Adapter
Mercedes RENNtech SL65 AMG Silver Arrow (685HP/870 lb-ft)
Machine is offline
Old 07-22-2008, 07:02 PM   #2 (permalink)
chuckster57's Avatar
I'd be willing to bet that the drain is plugged on the evaporator. It's the "pan" in the cab and if you look under the truck on the passenger side in the engine compartment near the firewall you should see a "rubber" hose that the water drains out of. Some have a formed edge that doesn't allow "outside" stuff into the interior. If you live in a dusty area they can seal themselfs shut when the dirt gets wet and turns into mud. If you run your A/C for a while and then park it,do you see the puddle of water? If not then It is a good possibility that that's what it is. Once it's cleared out it should dry out and the smell should go away. I think (dangerous ) that you can buy A/C fresheners from the auto part store
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is online now
Old 07-23-2008, 10:20 AM   #3 (permalink)
Company Cars
We have this problem with a fleet of company vehicles, because most folks don't know that the AC should be turned off and the vehicle run (with heater/ac fan on) for a few minutes before turning off the engine. This will help keep everything dried out.
chuckster57 might have the fix. Once fixed dry it out after every use.
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
Old 07-23-2008, 05:40 PM   #4 (permalink)
You bring up a great point. I don't recall seeing water drain off from the AC when it's been running lately. The truck is on dirt / gravel roads 30% of the time... I'll check it out tonight. Thanks.
Machine is offline
Old 07-24-2008, 09:56 AM   #5 (permalink)
Why do I have to "clear out" my truck but not in my Civic?
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
Blk88GT is offline
Old 07-24-2008, 12:38 PM   #6 (permalink)
doczenith1's Avatar
My Photos: (11)
That's the million dollar question. I've never experienced this in any other vehicle but I have the issue with my truck.
I would also recommend spraying Lysol into the air intake on the passenger side under the dash while the truck is running with MAX A/C and the fan on high. I did this once and then started to use the 'dry out' procedure and have not had any issues since.
2002 F250SD Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. - added Silver Stars and SUVLights Harness, Pioneer Premier FH-P800BT deck, PRS-X220 amp and TS-W1240C sub, Pioneer GEX-P910XM XM Satellite Tuner, K&N FIPK, FM50 Delta Flow, ART Rotors, Performance Friction Pads, 285/75R16 Bridgestone Dueler A/T REVO's. - 12/01
2003 Mustang Cobra, black convertible. - 6/07
doczenith1 is offline
