Name this part - Diesel Forum - TheDieselStop.com
Old 11-28-2012, 02:58 PM   #1 (permalink)
Name this part
What is it and is this why my steering is whining kind of loud?? It looks like it is spewing oil!
Thanks for any feedback.
02 F-250 Lariat 7.3 PSD
78 hp Diablo Chip, Ford AIS, exhaust, Roll N Lock
285/75/16 Dueler AT's
golf is offline   Reply With Quote
Old 11-28-2012, 04:23 PM   #2 (permalink)
RT
RT's Avatar
Are you talking about the steering box in the center of the picture? How is your power steering fluid level? Have you ever changed the fluid?
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 11-28-2012, 05:11 PM   #3 (permalink)
ford_doctor's Avatar
Check the fluid level first. Also, I wouldn't say that the steering gear is "spewing fluid" by the image it would only be a small leak or seepage...
Did anybody notice the CAC tube above the steering gear wet with oil and possibly leaning onto the gear?
Ford Master Diesel Technician
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline   Reply With Quote
Old 11-28-2012, 05:18 PM   #4 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Ya, I'll bet that's more like the issue.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. Many other custom features.
fordsforever73 is online now   Reply With Quote
