The obvious questions.....Did you check all of the other brake hoses and brake lines to make sure that there's no other leak(s) in the system? Did you bleed all four brakes or just the rear ones? Are all of the brake bleed valves closed tightly? Do you have a brake bleed set up with a bottle so that air doesn't get sucked back in when you let up on the pedal and before you can close the bleed bolt?
While you were changing the calipers if the Brake Fluid level in the Master Cylinder resevoirs went down too low, air could've come in through the MasterCylinder. If it did, you probably now have air in the whole system and need to bleed all four brake calipers, and the ABS.
Even if the master cylinder didn't get too low, your truck has four wheel ABS - you probably still have air in the the brake system that doesn't get cleared out by old style brake system bleed of slowly depressing the brake pedal until the bubbles stop coming out. You may need to have the brakes bled with electronic tool that actuates the ABS controller while your bleeding the brakes and forces any other "hidden" air out.
One other thought - when I was young, an old timer told me to always put a brick or a piece of 2 by 4 under the pedal when bleeding the brakes. It prevents the pedal from going too far. Without any back pressure, you can damage the master cylinder because the bake pedal can travel beyond its normal range and breaks the diaphragms inside. (This applied to vehicles from 60's & 70's. Not sure about 21rst century ones, but I still do it just to be safe.)
That's a long shot - I'd double check for any leaks, buy more brake fluid, and bleed all four brakes more than once, and get the ABS bled too
'01 F350 XLT, CC, 4x4, V10, SRW, LWB, Auto, 3.73LS, Island Blue, Off Road Package,
Auto Hubs & Cab Clearance Lights. Autometer water temp, tranny temp, & vaccuum
gauges. Line-X Bedliner, & the "incredible self-locking tailgate." White Night Backup
Lights & Volvo-eating Class V Hitch. Reverse Sensors.
