need help to disable the auto locking door locks - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 12-16-2009, 12:31 AM Thread Starter
i have just started driving my 2004 f-550 service truck ( bought it new and has been my company's flagship untill now) i want to disable the the door locks from automatically locking when you reach about 5 mph. every time i get out on a service call and try to open one of the other doors i have to go back to the drivers door to unlock them. any help will be greatly appreciated
2000 F-350 4x4 6spd CC Lariat service truck
2002 F-550 4x4 6spd CC Lariat service truck
2004 F-550 2x4 auto CC Lariat service truck
2008 F-550 4x4 auto CC KR service truck
pollardfarms is offline
post #2 of 13 (permalink) Old 12-16-2009, 12:51 AM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
This is how I did it in my '05 F-350: It might take a few try's to do it in time.
Using the remote:
Must complete steps 1 thru 7 within 30 seconds.
1. Insert the key and turn to 4(on) position.
2. Press the power door unlock control three times.
3. Turn the ignition from the 4(on) position to the 3(off) position
4. Press the power door unlock control three times.
5. Turn the ignition back to the 4(on) position. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if auto lock was activated. NOTE: Pressing the power door UNLOCK/LOCK button again will toggle between activating and deactivating the autolock feature.
7. Turn the ignition to the 3(off) position. The horn will chirp once to confirm the procedure is complete.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #3 of 13 (permalink) Old 12-16-2009, 10:35 PM Thread Starter
thank you very much. and my dealer said it could not be done
post #4 of 13 (permalink) Old 12-16-2009, 11:18 PM
My Photos: (24)
If that doesn't work, and you have the keyless entry (number pad on outside of door) I have instructions for that method too. It's a little easier. Just let me know.
post #5 of 13 (permalink) Old 12-21-2009, 05:16 PM
Can you post that?
04 F350 CC FX4 MAC intake, Progard filter, DR levelling kit and 35 X Terrains.
89 F350 CC 4x4 Longbed Lariat. 7.3 with ATS Turbo and K&N. --SOLD--
More mods as the money allows.
MonkeyBoy is offline
post #6 of 13 (permalink) Old 12-21-2009, 08:59 PM
My Photos: (24)
Here you go:
This is from my '05 manual: To deactivate/reactivate the autolock feature using the keypad.
Your vehicle comes with the autolock feature activated. To deactivate/reactivate this feature:
1. Ensure that the anti-theft system is not armed.
2. Turn the ignition to the 3 (off) position. (One "click" up from when you put key in).
3. Close all the doors, liftgate and cargo doors.
4. Enter the 5-digit entry code.
5. Press and hold the 7/8. While holding the 7/8, press and release the 3/4.
6. Release the 7/8.
The horn will chirp once when the system has been successfully deactivated.
The horn will chirp twice (one short and one long chirp) when the system has been successfully reactivated.
post #7 of 13 (permalink) Old 12-22-2009, 09:01 AM
frick134's Avatar
First Year for auto locks?
Does any body know what was the first year ford started with the auto locks? Can't seem to get this to work on my 99. Thanks
1999 F250 PSD 4x4 Supercab Longbed 7.3L
Truck Build Date: 01/99 Kentucky
Replaced:Batteries, Alternator W/200amp
Pulling 37' 5th wheel
Dieselsite 203* theromstat/coolant filter 10/05
Custom Built Lower Front Receiver
4" trubo back Exhaust 10/08
BTS Transmission 11/08
BTS Tunes 11/08
BD X-Monitor 11/08
08 Diff Cover 1/10
08 Mirrors 1/10
frick134 is offline
post #8 of 13 (permalink) Old 12-22-2009, 11:41 AM
Thanks FordsForever73
post #9 of 13 (permalink) Old 12-22-2009, 11:48 AM
My Photos: (24)
I got my info from the factory manual that came with the truck. If you don't have yours, maybe someone you know has a manual for the '99? Good luck. It is an awesome thing, to deactivate the annoying chime.
And to the previous owner of my truck, thanks for deactivating the "also annoying" chime for the seatbelt.
post #10 of 13 (permalink) Old 12-22-2009, 06:32 PM
I looked in my 2000 F250 manual, and couldn't find anything that allows you to alter the auto locks. I thought my auto lock feature was a result of the Viper remote start alarm system I had installed way back in 1999.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, BAK RollX bed cover, Bed mat, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, undercoated, 149k somewhat trouble-free miles (so far) [never back to dealer for anything] , Edge Evolution (60 HP setting), Pioneer DVD/CD/iPod/XM satellite
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2) and tension pullies, all 4 power lock actuators, water pump, air conditioning lines and compressor, battery cables
2016 Subaru Outback (Wife's commuter car)
short_stuff is offline
post #11 of 13 (permalink) Old 01-02-2010, 12:08 PM
Can you only disable the Autolock or can you alter it to unlock when the shifter is put back into Park? My girlfriends Escalade does this and it makes the Autolock feature much more user friendly.
rechromed2 is offline
post #12 of 13 (permalink) Old 01-03-2010, 11:14 PM
Matt0987's Avatar
If you go to this site you can get a PDF copy of your owner's manual for your specific year Ford vehicle. It should have this information in your vehicle specific owner's manual.
https://www.flmowner.com/servlet/Con...OwnerGuidePage
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook monitor (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer
Matt0987 is offline
post #13 of 13 (permalink) Old 09-30-2010, 12:30 PM
Any help on the auto locking door locks for a 2000 F350 7.3 SD?
We live in an area that makes me uncomfortable when my wife drives it. auto door locks would give me a piece of mind for her safety.
I tried the '05 (Fordsforever73) post and it did not chirp or honk the horn for confirmation.
erikl is offline
