Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 09-20-2005, 06:14 PM   #1 (permalink)
need help ford cant seem to find the problem
i have a 05 supercab fx4 psd and the dome lights on the back of the cab seem to work intemittenley the seat belt chime acts up and doesnt work properly , the back up sensors give a solid beep when put in reverse but theirs nothing back their, i have also lost all my dash gauges and then they came back on like everything was normal so i dont know what the problem is here, i took the truck to ford yesterday and they couldnt seem to find any problems with the truck while i sat their for three hours. so any help would be greatley appreciated. thanks
strokin05 is offline
Old 09-21-2005, 07:15 PM   #2 (permalink)
Re: need help ford cant seem to find the problem
anybody out their that can help
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 09-21-2005, 08:19 PM   #3 (permalink)
Seems like a lot of things to go wrong and all be related. Dome light issues can be related to the door latch. Mine did that too. Check the latch assembly in the drivers side door (I guess both, but because you use the drivers side the most, it is more likely to fail). The latch can lose its lubrication and then it doesn't complete the circuit. No circuit, and dome light stays on, and maybe other crap happens because the truck thinks the door is open.
It's a long shot, but what I do when mine acts up is spray some WD40 in there, and then open and close it a few times, then spray some more. Then just wipe the excess off. I'm good for 6 months then. I thought it was my own fault because I wash it a lot and maybe that degrades the lubrication. Or maybe it is just another FMC shortcoming.
Let me know if that helps...RL
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures: http://community.webshots.com/user/ralphinnj
6L Shootout Report:
http://www.thedieselstop.com/downloa...toutReport.pdf
ralphinnj is offline
Old 09-21-2005, 11:01 PM   #4 (permalink)
IMO it sounds like a loose or intermitant ground. Or a loose connector on the wiring harness.
2006 F-550 4X4 Crew cab 6.0L 200" WB
2006 F-350 SRW King Ranch
91 F-250 4X4 7.3L ZF 4.10 posi K&N, Straght piped, 9000lbs mile marker, Channel Iron winch bumper, Warn Premium hubs
84' F-150 5.8L H.O. 4X4 4.10 posi K&N Dual Glass packs 8000lbs Warn winch 4" Lift 35's
88' Ranger - Currently Under Transplanting
(460CI w dana 50 and ford 10.25)
Alberta_Mud is offline
Old 09-22-2005, 12:21 AM   #5 (permalink)
A.M. is on the right track. You almost certainly have a grounding issue. G.M. vehicles use whats called a "body control module" which is a sub-processor that controls most non-powertrain functions (buzzers, warning lights,security syst. etc.). I'm pretty sure Ford uses a similar system. I'd bet the body control module is either improperly grounded or faulty.
2006 F-250 4X4 Lariat, C.C. / SWB -- Torreador red
PerryB is offline
Old 09-22-2005, 06:10 AM   #6 (permalink)
clamgulch's Avatar
Ford calls their version of the body control module a "GEM"...Generic Electronic Module. I just replaced mine in the excursion and the new one appears to be defective (horn honks when I touch the keypad or lock the door). $270 at www.fordparts.com. It is a complicated computer with lots of teeny tiny doodads on it (not zoodads), so you aren't going to "fix it" with a soldering iron.
It's located right between Hell and the Lake of Fire, attached firmly to the back side of the electrical junction box (fuse box) that is directly above the emergency brake release handle. What usually causes failure is a leaky windshield.
Good luck- you're going to need it along with a 5 pound tin of patient endurance...or maybe I'm just thinking about me. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 09-22-2005, 03:39 PM   #7 (permalink)
Send a message via ICQ to 96Cobra
GEM has been gone since the 2002's started rolling off the lines. I thought that there was soneone else on here a while back with basically these same problems, and I believe it was a bad instrument cluster. I also seem to remember seeing a TSB about this.
Roger
2002 F350 XLT, CC, SB, 4x4, Auto, AIC, DiabloSport Predator, BD X-Monitor, Kenwood TM-V7A, Pioneer 7400MP3, Infinity 5.25" Components, Infinity 10" Sub in a Q-Logic Box, Heated Mirrors, Gentex/Mito Auto Dimming Mirror, Rear ID Bar, Uniden PC78 Elite CB, Clifford Matrix RS3 Alarm/Remote Start, Keypad Entry, Homemade "Tymar", custom, muffler back exhaust, 6 Whelen LED's in rear window, 6 Whelen Strobes in the Front, Rears still not installed...
96Cobra is offline
