Need info on replacing front disc pads on a 2003 F350 FX4 - Diesel Forum - TheDieselStop.com
Old 06-23-2006, 07:13 PM   #1 (permalink)
I would like to replace the front disc pads on my 2003 F350 FX4 and have the rotors turned. I've done this on a number of other vehicles - never on something this large. I looked at the calipers and there appears to be 4 bolts on the inside (engine side). Two are larger than the other 2. Do only the 2 largest (top and bottom) ones need to be removed? If someone who has done this could give me a quick run-thru, I'd sure appreciate it or point me in a direction with some DIY instructions.
Thanks,
Professor
2003 PSD, F350, FX4, CC, dually, Super Chip, 4" stainless exhaust, 4 gauges on pillar & 4 gauges above mirror, XM radio, Reese 20K 5th wheel hitch. 3,000 miles so far on VO since conversion.
theprofessor is offline
Old 06-23-2006, 09:58 PM   #2 (permalink)
JimTJr's Avatar
My Photos: (20)
Re: Need info on replacing front disc pads on a 2003 F350 FX4
Remove the larger ones, I think,, (The two that hold the bracket on,,)remove the caliper and bracket there it mounts to the spindal, you need the bracket off to get the rotor off too. IF You were just doing pads then the smaller bolts would just remove the caliper...
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 06-24-2006, 09:09 AM   #3 (permalink)
Hey Professor, the directions were sent.
Keith
2004 F350, Lariat, True Blue/Arizona Beige, CC, LWB, 6.0 PSD, Torqshift, FX4, Camper package, captains chairs, power & heated TT mirrors, adjustable pedals, AIC, dual alternaters, power sliding rear window. C-Betr mirrors, ARE K series cap, Bedrug, BFG MT 285/75r16,overhead DVD player, DPPI turboback dual exhaust, gauges, Husky mudflaps, Weather tech vent visors, and Lund bug deflector. Date ordered 12/23/2003. Delivered 2/5/04
http://community.webshots.com/album/122797684QJFiJY
MD-TDC Secretary
ktpauley is offline
