Need More F250 Headlight Aiming Advice - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-17-2006, 07:54 AM Thread Starter
Reference my previous post a few days agao regarding how to adjust headlights. Last night I drove my F250 and my wife brought her Jeep Cherokee for comparison over to a dark parking lot. While I could adjust both beams up/down and side to side, I found that the right headlight had a distinctly different beam pattern compared to the left side. I stood in front of each headlight one at a time to see the effect of only one beam. The right beam pattern was actually two distinct bright patterns with one pattern higher than the other while the left beam was a much more even pattern similar to the sealed beam pattern from my wife's car. No amount of adjustment of the top two adjusting screws had any impact on the beam pattern.
Is there a third adjustment (beam pattern?)that requires a special tool or is there something else going on here?
Thanks;
Dick
2009 Lariat V10
dclark1946 is offline
post #2 of 6 (permalink) Old 09-17-2006, 08:06 AM
Bear_Hunter's Avatar
My Photos: (9)
Re: Need More F250 Headlight Aiming Advice
If your talking about adjusting the beam pattern like a flashlight...no you can't.
Are both bulbs the same in your headlights?
JAKD 2007 Dark Stone Harley Davidson Edition Super Duty Custom Built By Trucktoyzperformance.com
Special Thanks to: Trucktoyzperformance, Autometer, Rize Industries, MBRP, Line-X of Friendswood TX, Accufab Racing, Painless Performance, Retrax, OilGuard, and DC Customs
Also brought to you by Critical Fight Gear & Suckerpunch Entertainment
Bear_Hunter is offline
post #3 of 6 (permalink) Old 09-17-2006, 02:09 PM Thread Starter
Well the bulbs are hidden behind the small bulb reflector (not the main big reflector). It looks like the small bulb reflector distance to bulb might be adjustable but I don't know how that adjustment is made.
Dick
2009 Lariat V10
post #4 of 6 (permalink) Old 09-17-2006, 04:29 PM
sbrennan007's Avatar
Your not going to be able to adjust the beam pattern. This is in the structure of the lens and housing itself.
The above suggestion about checking the bulbs to see if they are the same is good. I have run across situations where the bulbs were made by two different manufacuters and the pattern was different.
Again not to say that installing new bulbs is going to adjust the beam pattern in this case.
2013 BMW X5 M Sport
2011 BMW 335i M Sport Convertible
sbrennan007 is offline
post #5 of 6 (permalink) Old 09-17-2006, 07:06 PM Thread Starter
OK I will pull the bulbs and check. I ran into a similar situation with my 89 Mustang after replacing the fogged original headlights with repoductions and there was a problem with poor beam pattern. Had a mechanic inspect the headlights with an alignment tool and he told me that the filaments were the problem. I replaced them with Sylvania bulbs but no difference. I replaced those with different (better) headlight asemblies and the beam pattern was significantly better.
Dick
2009 Lariat V10
post #6 of 6 (permalink) Old 09-18-2006, 08:50 PM Thread Starter
I was able to pull the right bulb (the one with a split beam pattern) There was no mfg. name on the bulb unless it is hidden by the socket. I was not able to get the left bulb out for some reason. It is very hard to get to.
Dick
2009 Lariat V10
