Need some more VSM help - Diesel Forum - TheDieselStop.com
Old 11-18-2009, 07:04 PM   #1 (permalink)
How do you get the module out of the bracket? Do you need to unbolt the bracket from the firewall??
2002 f250 7.3 lariet cc auto srw short bed 3.73 gears,16k reese slide hitch,reese brake controller,banks 4inch monster exhaust,autometer lunar guages tranny,boost,egt.aFe air box,sonnax valve and tri springs,magnefine,factory aic,led lights in running boards,TS 4pos chip,DR 4.5 lift
03 tt heated/signal mirrors,wicked wheel
94 Pace Arrow 33L Class A P30 454
04 custom ridgid chopper 120RWHP
http://community.webshots.com/user/oneHD
HDone is offline
Old 11-18-2009, 11:02 PM   #2 (permalink)
hdone,
If you can see the VSM mounted on the firewall, it is attached to it with two bolts. I used a metric socket (don't remember the size) to remove the left side bolt first. If I remeber right the right side was a little more difficult but can be removed with a little time.
I don't remeber any brackets
http://i684.photobucket.com/albums/v...9/DSC01560.jpg
http://i684.photobucket.com/albums/v...9/DSC01559.jpg
Mark
gp49 is offline
Old 11-19-2009, 06:36 AM   #3 (permalink)
Thanks Mark. I thought that connector peice slid out of the box. Looking at your pics I see its all one peice. These moduals are on back order. They are like 800 peices behind. My have them in a couple months. Wonder if there is a problem with these just like the CPS?
HDone is offline
Old 11-19-2009, 11:05 PM   #4 (permalink)
I don't think it's as bad as CPS, but there is for sure a lot of '02 with the same problem.....
I supprised that they are out of stock. When I was checking into the $ I called about 5 local dealers. 4 had the module in stock (priced from 195 to 300 !!!) the 5th tried to sell me a GEM for 395 ! I run from them as fast as I could.
Did you try the correct website I gave you in the PM ? You can get a very straight (true) answer from Ed about availability.....
Mark
gp49 is offline
Old 11-22-2009, 12:04 PM   #5 (permalink)
Yea Mark my local dealer told me it first. I left a message with Ed and he called me back and checked and said the same thing. He said he might be able to find one but would be close to full list if I wanted it right away. Ed was real nice and a straight shooter on the phone and answered email within a hour or so. I put him into my ford contact folder.
thanks Mike
HDone is offline
