New brake fluid, new brakes - Wow! - Page 2 - Diesel Forum - TheDieselStop.com
Old 02-19-2008, 05:02 PM   #16 (permalink)
I ordered part# SB 1010 I called because I couldn't find them on the site and confirmed fitment. Nice people.It's the same size for the front and back. The tube is reusable and was a couple bucks extra but is chemical resistant if it makes a difference. I usually have to work by myself because of my schedule. You replace the stock bleeders with the Speed Bleeders permanently and all you need to do for a change is open the bleeder and pump the petal while watching the reservoir level and check the color of the fluid once in a while. For me it is money well spent for the time I save.
2002 F250 Lariat 4x4 Extended cab SB
BD Power X Monitor
brocanicbob is offline
Old 02-20-2008, 01:21 PM   #17 (permalink)
High PSI's Avatar
My Photos: (18)
I haven't used mine yet and didn't know that they were permanent.
'02 Black F350srw,Lariat,CC,SB,OR. - BTS TRANS,Coated 1.00 BB TN-non EBP-6.0 Spearco IC-DP Tunes(stock,HI,60T,80E,120R)MAP maximizer-ITP reg ret.-AirDog-Fluidampr-BWD coated/ bellowed pipes-AFE2-4" Magnaflow-Dieselsite coolant filter&ESOF SS lines-Billet/203*stat-Fleetrite ELC-Bilsteins-Hawks&Cryo's-Centramatic-Billet-Extang-Husky box-Husky Liner-EGR-LineX-Alpine-Kicker-PIAA-Dynamat-Sirius-Viper-ES Poly's-BFG 315/75/16 AT's-DTS 4.56LS-31 row 6.0 Cooler-UltraLite trans,pyro,boost-DiPricol fuel-PML pan-Mag-Hytec cover-Powerslot-Hawk. Marinco,Snowman,Harpoon,AIH,CCV,foil,door ding,console mods. http://good-times.webshots.com/album/557543120DKiWId
High PSI is offline
Old 02-20-2008, 01:33 PM   #18 (permalink)
doczenith1's Avatar
My Photos: (11)
Originally Posted by High PSI View Post
Sticking slide pins.
If they were sticking that bad why wouldn't they stick under moderate brake pressure? The force required to squeeze the brake pads against the rotor to cause heavy breaking force has to be way higher than the friction in the slide pins. And when I say they don't release immediately I mean it's like I'm still applying the same force to the brake pedal. It's not just a slow release. The last place I had work on my brakes was a reputable shop and I am certain they would have lubed the slide pins correctly. How often do they need to be re-lubed? If it were warmer here I would have already pulled a caliper and checked the pins but my fingers don't work well in temperatures below 20 degrees. Thanks for all the help.
Al
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
Ordered 10/27/2010
Delivered 12/13
2003 Mustang SVT Cobra, black convertible. - 6/2007
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
Link: Differential Cover Spreadsheet
Link: Fuel Mileage Spreadsheet
Link: Rapid-Heat Sup Cab Heater Test Graphs
doczenith1 is offline
Old 02-20-2008, 04:09 PM   #19 (permalink)
You just replace the stock with the Speed Bleeders and they will always be ready for your next service.
BD Power X Monitor
Old 02-21-2008, 10:40 PM   #20 (permalink)
Originally Posted by Meatco1 View Post
I like your idea of using clear tubing to flush.
Please tell me what diameter tubing you bought from Lowe's, and what dept you found it in.
I'll run down there and buy some, but I just don't remember seeing it there.
Thanks,
Richard
Richard,
It's 3/16" dia. clear vinyl tubing, found in the plumbing section, I believe. If not plumbing, try the hardware section. They had a wide selection of tubing available. Hope this helps!
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 02-21-2008, 10:53 PM   #21 (permalink)
Meatco1's Avatar
Thank you, I"ll drop on down to Lowes tomorrow.
Richard
2001 C/C, 4x4, S/B, 3:73 L/S
John Wood Transmission
Tru-Cool Transmission oil cooler
DP Tuner with No Start, 20/40/60 Tow
80 Econ., 120 Race
AutoMeter 3 Guage, Pillar mount
6637 w Pete's Cover
Euro Chrome Clear Headlights
Euro Clear Signal Corner Lights
Bright Box Upgraded Headlight Harness
Defiant Light Bar w 2 KC Pencil Beams & 2 KC Driving Lights
Fumoto Drain Valve
Coolant Filtration System
Meatco1 is offline
