Re: New Excursion- some ?'s
Welcome back! There has been lots of changes just in the last year, especially with engine tuning and horsepower now approaching 750 hp at the rear wheels for properly built 7.3 race and/or pulling engines. Admittedly, that is rare, but not unheard of. Also, you might want to post excursion specific questions in the excursion forum.
Mandatory: Gauges! Pyrometer, boost and transmission temprature. Those are mandatory and should be your first mod, and those of us that have trashed engines and transmissions are pretty much in agreement on that. Several sponsors carry gauges and A-piller pods at great prices.
Suspension mods on the excursion are worthwhile. The stock springs are too soft and may be sagged down to the point where the bump stop is sitting on top of the spring hold down cap. Bilstein shocks seem to be the rage, but I don't use them. Rear anti sway bar if you don't have one from the factory, Radius rods for the rear springs, 4" exhaust, AFE stage II air intake (or equivilant). Fuel system mod to get rid of the air sucking quick disconnect fitting in the suction side between the tank and the fuel pump, a multi position switchable on the fly chip from DP Tuner, aka Jody Tipton.
Just keep in mind that you have powdered metal connecting rods and you need to stay under the threshold of their instant destruction tendencies which begin at 350 hp with bad ECU programming.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
