No Dashboard Lights - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-03-2006, 07:04 AM Thread Starter
No Dashboard Lights
I have lost my dashboard lights on my 99 F250. Any thoughts as to where I should look and what I should be looking for? Has this been common in these trucks. I have had my F250 for just over a month now.
2011 F150 XLT
3.5L Ecoboost
Iceman31 is offline
post #2 of 8 (permalink) Old 02-03-2006, 09:47 AM
Re: No Dashboard Lights
Do your tail lights work? It will be the same fuse (designed that way to alert you to tail lights out). Other causes could be the bright/dim control for the dash lights.
2002 F350 4x4 CC DRW Lariat 7.3 auto 4.10 LS diff.(bought 5-05 @ 76,000 miles) Pyro, Boost, and Trans gauges. AIH delete. Tru-Cool Max trans cooler. Magnafine filter. Royal Purple MAX synthetic ATF. 55 gallon aux bed tank. 2LO Mod.
2002 Holiday Rambler 30-SKS Alumascape fifth wheel
24 foot gooseneck livestock trailer
1940 McCormick Deering restored Farmall H, used weekly (the grand-daddy of International)
Used goats for rent
twobit is offline
post #3 of 8 (permalink) Old 02-03-2006, 01:21 PM Thread Starter
My tail lights work like they should and my dim switch is turned up as high as it can go. I do not have any dashboard lights at night. All my dummy lights work just fine also. It just seems to be the backlight that illuminates things at night.
2011 F150 XLT
3.5L Ecoboost
Iceman31 is offline
post #4 of 8 (permalink) Old 02-03-2006, 04:26 PM
this may sound dumb but did you check the dimmer switch?
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
post #5 of 8 (permalink) Old 02-03-2006, 04:29 PM Thread Starter
Yes, was one of the first things I checked.
2011 F150 XLT
3.5L Ecoboost
Iceman31 is offline
post #6 of 8 (permalink) Old 02-04-2006, 05:53 PM Thread Starter
Well upon further inspection my tail lights did not work. I had brake lights and signal lights but no tail lights. My fuse #8 I think was the culprit, I changed it and all seems good now. Thanks for all your advice!
2011 F150 XLT
3.5L Ecoboost
Iceman31 is offline
post #7 of 8 (permalink) Old 02-04-2006, 09:31 PM Thread Starter
OK now I have a new issue. The 15A fuse blows very quickly. I just went through 3 of them and the longest lasted about ten minutes. The first blew when I let off the e-brake, then the next one lasted ten minutes and blew while I was out driving on the road. The next blew when I replaced it and closed the hood. What am I missing here? I recently had my brake controller switch from my old truck to this one could this be causing my problem somewhere? Any thoughts?
2011 F150 XLT
3.5L Ecoboost
Iceman31 is offline
post #8 of 8 (permalink) Old 02-04-2006, 09:41 PM
dondiesel444's Avatar
I have had this problem also, I replace the fuse, and sometimes it will blow in 10 minutes, other times it will be ok for a few weeks. I ahte electrical work and tracing wires, but i guess I have a short somewhere. I have heard of other Superduties with this problem, but I have never found a fix. it must be a semi-common problem....
2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks:
2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner..
late '99 F-350 PSD CC LWB 4" lift, 315's, DP......
early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc....
1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
dondiesel444 is offline
