No power windows or radio at startup??? - Diesel Forum - TheDieselStop.com
Old 10-14-2009, 11:29 AM   #1 (permalink)
Hi Everyone,
Have had the above intermittant issue for awhile now. Thought i'd run it by everyone.
So occassionally when i start up the power windows dont work and the radion doesnt work...then within 5 min or so they work.
I am assuming some kind of short or corrosion on some wires or something.
Thanks,
Terry
2003 F350XLT Shortbed CrewCab 4x4 7.3l 6 speed. 3.73 LS, 9900# GVWR Package.
Major Tow MODS:
05-07 Facelift. PHP 65 tow on PCM. RifRaff FRx. ATS Compressor Housing. Turbomaster wastegate controller. SP Diesel exaust brake. Midwest Trans short throw. 2" Edge Lev Kit. AFE Stage II. Bilstiens. Hellwig 1 1/4" rear sway bar PN 7636. Hawk HP Superduty brake pads and Powerslot frozen rotors. Autometer Ultralight guages. South Bend Clutch - MU 1944 Con 0. Walker BTM. 6.0 Intercooler. B&W turnover gooseneck hitch. 6980 unladen weight. 260,000 miles. 20 Foot Cimarron Gooseneck Horse Trailer. Oilguard bypass filter.
2008 rearend cover.
Sold:
1991 F250XLT Supercab 4x4 7.3l 250,000 miles.
terryf350 is offline
Old 10-14-2009, 11:04 PM   #2 (permalink)
KevinTamu's Avatar
I'd try the accessory relay in the fuse compartment below the steering wheel. There are two columns with relays stacked on top of each other, I believe its the column on the right,and the relay on the bottom of that column. The writing on it should be upside down. Check it out and maybe try getting it replaced. That, or it could be your door switches, but my money is on the relay.
2006 F-350 King Ranch 4X4 - 63K miles
- Jl 13w7 powered by 1000/1v2 --- 2 Yellow Tops
- Jl 8w7 powered by 250/1 --- 220 Amp HD Alternator
- JBL performance components powered by Jl Amp
- All ran by Double Din Pioneer --- ARP STUDS
- 30 Farad Stinger Capacitor -
- 4.5 Don. Rac. Lift Kit --- Eric's Custom Tunes
- 35X13.5 Dick Cepek --- 4 Guage Pillar Mount
- 18 inch Mazzi chrome rims
- Excalibur remote start alarm
- 5 inch custom exhaust
- Many more cosmetic mods and SCT custom tune.
KevinTamu is offline
Old 11-25-2009, 11:50 AM   #3 (permalink)
fixed
i swapped relays as the guy above suggested. No radio or window problems since.
Thanks,
Terry
Major Tow MODS:
2008 rearend cover.
Sold:
Old 11-25-2009, 12:57 PM   #4 (permalink)
Also, be aware that if you have the OEM clearance lights on the F-350, those can (and do) leak rain water, and can (and do) spill onto your electronics on the driver's side. At least it is something to keep an eye on.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
