notice the truck is taking a while to start.. - Diesel Forum - TheDieselStop.com
Old 10-06-2008, 05:23 PM   #1 (permalink)
06 6.0L 54k miles, same batteries from when it was bought...
I have been noticed my truck has been taking a little longer to start up when i turn the ignition. Sometimes I will have to try 2 or 3 times holding the ignition for prolonged periods of time.
I have drained any water from the fuel system by removing the plug under the cab along the frame rail. I have checked both batteries for good connections and all is good there.
What could it be that is causing this? It used to crank it very quickly. Yes, I do wait for the coil/spring light to go away in the dash before turning it over.
jonlorio is offline
Old 10-06-2008, 11:20 PM   #2 (permalink)
It's possible that its a high pressure oil leak, but I would get the batteries tested before I invested any time getting the truck checked out.
I think my stock batteries lated untill about 75-80k miles.
2004 F-250 King Ranch CrewCab ShortBed 6.0L
kc2kgt is offline
Old 10-07-2008, 09:54 PM   #3 (permalink)
truck is at the dealer. will keep you updated.
jonlorio is offline
Old 10-09-2008, 11:50 AM   #4 (permalink)
I had this issue on my 7.3 turned out one battery was bad. Be sure to disconnect one if you have them tested so they are tested individually. I replaced both batteries and now it fires right up.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, Triple disk converter, whicked wheel, 203 t-stat, High pressure bypass, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom 86gal AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
