Oil Filter suggestion - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 06-19-2017, 04:53 PM Thread Starter
I am looking for a suggestion on an oil filter to use. I have been through several different brands. I am looking for one with a flat gasket. I have tried quite a few with the tapered gasket like the Motorcraft and they all start leaking on me. I was using the Mobil 1 filters but they no longer use the flat gasket. So far the only ones I have found are the Baldwin brand but they are hard to find and are pretty pricey. Thanks.
mmsafd is offline
post #2 of 3 (permalink) Old 06-19-2017, 06:46 PM
FleetMan's Avatar
If Baldwin is your preference, Filterbarn.com might be a place to check.
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
FleetMan is offline
post #3 of 3 (permalink) Old 06-20-2017, 06:39 AM
ArcticDriver's Avatar
There is something else going on if the tapered gasket constantly leaks on you.
Either your installation procedure is not correct or the mating surface is not clean (or maybe has scratches, pitting or corrosion).
Tapered gaskets work flawlessly for millions of Super Duty owners every day.
What are your installation practices?
Have you closely inspected the mating surfaces ?
2000 F-250 4x4 SC SB 7.3 PSD w/4R100. 160,000 miles.
NOS Black CPS. Rebuilt Fuel bowl w/gold spring, 6.0 Cooler, Walker BTM, Stancor GPR, AIH Delete, ScanGauge II, AIC, 2002 Headlights, Bilstein 4600, Marinco Mod, Cupholder Upgrade, B&W Turnover Ball, Michelin LTX
2002 F-250 4x4 CC SB 7.3 PSD w/4R100. 160,000 miles.
NOS Black CPS. ScanGauge-II, Bilstein 5100, Marinco Mod, B&W Turnover Ball, Michelin Defender LTX
ArcticDriver is offline
