Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 10-12-2005, 09:44 AM   #1 (permalink)
Oil for this winter
I live in mild OK where it gets to 0 once a year and I can plug it in, but I will be going skiing in december. Last year at 9000 feet, it was 15 below at night. I don't know if I'll have a plug available.
Questions:
1) I have fresh oil in there, do I need to swap to 10-30 for that one trip or can I make it on the thick stuff?
2) If I can't find a plug, I was thinking of a small propane space heater, like I use in a tent, to put under the oil pan. Would that work?
First mountain trip in a diesel for me.
2005 F250 6.0L CC FX4 King Ranch Dk Copper Color Matched LineX and a Retrax cover
gecko2424 is offline
Old 10-12-2005, 10:01 AM   #2 (permalink)
My Photos: (21)
Re: Oil for this winter
10-30 is good down to -10F. Unplugged it'll sound like a 76 Pinto when you start it up, and it'll take forever to get up to temp, but IMO you'll be fine.
Hear's a handy TSB that addresses the issue of cold starts.
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 10-12-2005, 10:18 AM   #3 (permalink)
OOPstroker's Avatar
If your staying at a lodge there should be plug in's available. The only place you might be sol is in the parking lot on the hill while your skiing and you shouldn't have any trouble during the day as long as you got the right fuel or some Howe's added in.
Throw in some jumper cables though just to be safe.
I run Amsoil 5/30 and live in SD and have yet to have a starting issue, usually plugged in or in the garage though but there are times when were traveling and snowmobiling that it gets left to fend for itself.
OOPstroker is offline
Old 10-12-2005, 01:00 PM   #4 (permalink)
JimmyDee's Avatar
My Photos: (24)
A good 5w30, 5w40 synthetic oil will sure help you a lot. Living here in Michigan I use it in the winter and it makes all the difference in the world for the cold start.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod; 4" Exhaust, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in Dash; AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
Old 10-13-2005, 11:44 AM   #5 (permalink)
I am in Oklahoma, too and spent last winter in Wisconsin. The 10/30 is MUCH better than the 15/40 for winter starts. I'd just switch to 10/30 before the trip and run it until your next regular oil change. The 10/30 will be fine for Oklahoma winter and as long as you get back to the 15/40 by next summer, it'll be fine.
2001 F 250 Platinum Edition
7.3 PSD CC SWB 4x4 3.73 LS 4 spd auto
Mods- Autometer Tranny Temp Gauge, Hard Tonneau Cover
wandrews is offline
Old 10-13-2005, 12:03 PM   #6 (permalink)
I have been to Colorado hunting the last part of October several times with a PSD. I've never checked the temps but it was cold. I have let my truck set for a week at 9000 ft and have never had a problem starting it. Mine isn't the only one that has been there either. None of them have ever had a problem starting. They have all had 15-40 oil in them.
FYI the small number is the cold number and the big number is the hot number. If I was going to switch to something else for those conditions I would switch to a 5-40.
444-4D is offline
Old 10-14-2005, 01:34 PM   #7 (permalink)
sounds good.
Any response to my space heater idea? My father in-law, lifetime trucker, used to build small fires under their oil pan back in the day (one of many stories) That or ether...and I'm not doing that.
Old 10-14-2005, 03:44 PM   #8 (permalink)
sounds good.Any response to my space heater idea?
Yeah, I think is't a bad idea. It might be an option in a jam but it's not something to make plans for.
I saw my dad build a good sized wood fire and pile the hot coals under the oil pan of a 220 Cummins in an old DCO. Are you married to my sister [img]/ubbthreads/images/graemlins/laugh.gif[/img].
444-4D is offline
Old 10-16-2005, 09:26 AM   #9 (permalink)
40 or 50 years ago, nothing was as good as it is today. the oil didnt flow in the cold. the starters and batteries were crap too. i remember those days,,starting fluid was a must if you wanted to start those old cummins and mack diesels. dont use starter fluid, ether, in a glow plug engine. it can cause fires etc iside the intake system. i remember the old 335 cummins actually having a little furnace type burner built into the intake manifld. you pumper up fuel pressure with a hand pump and the lit the fire with a glow plug type ting and when the manifold was hot as hell, you tryed starting it. lots of white smoke out of the exhaust, ha ha. those were the good old days. my 1980 freightliner with the 600 hp kta cummins would pass anything on the road, but needed ether to start if the temp was below 35. without it, it would crank all day without starting. a little wiff of ether and she would fire right off.
04crew is offline
Old 10-16-2005, 10:49 AM   #10 (permalink)
I run 15-40 year round, changing to 10-40 this year. Cold starts rumble like he!! but it will start, Cycle the key a couple times so the glow plugs cycle twice before trying to start. also, all you need is a small metal pan and a few chunks of charcoal to warm a oil pan before starting if you want to warm your oil before starting. (not needed unless it won't turn over)
used to do this with big trucks, a tray with charcoal slides under easier and the heat rises straight up. just be careful not to melt any plastic parts.
stumper is offline
Old 10-16-2005, 11:48 AM   #11 (permalink)
JimmyDee's Avatar
My Photos: (24)
If this if for a diesel, make sure the 10-40 has a diesel rating. I'm not aware of an oil rated for diesel that is a 10w40.
Jim
JimmyDee is offline
Old 10-16-2005, 04:43 PM   #12 (permalink)
Shell Rotell [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]a is.
2000 Ford XLT 7.3 L PSD 4X4 Super Duty. Zoodad, Gibson Cat back Dual, Toucan Intake.
Yeat is offline
Old 10-17-2005, 08:40 AM   #13 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Shell Rotella T is 15w40, not 10w40. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
SmokeyWren is offline
Old 10-17-2005, 09:50 AM   #14 (permalink)
Smokey...my Rotella T (that I used for the first time Wed) is 5W40 and says it is synthetic.....I don't recall what the other 15W40 Rotella was called [img]/ubbthreads/images/graemlins/confused.gif[/img] as I've been using Delo. This time is just an experiment to see if it makes any difference. It does specify improved soot control whatever that really means and is CI4+ rated
Ian
2004 PSD F350 Lariat 4X4 CC long box Arizona Beige , AIC, FX4 heated seats, adjustable pedals, power rear slider, towing pkg/ receiver, power Towing mirrors, camper pkg,reverse sensor, 3.73 LS, torqueshift, bedrug, born on Dec 3 2003. Towing 2005 Cougar 5th wheel 285 EFS with a bell and two whistles.
ikidd49 is offline
Old 10-18-2005, 10:23 AM   #15 (permalink)
Schaeffers 9000 5W-40 have been turning in outstanding (maybe the best of any oil) UOA with the 6.0L PSD. I'm going to change out my MC 15W-40 next month for the 9000.
<font color="red"> '05 F-350, CC, PSD, 4.10, DRW </font>
mettech is offline
