Overhead message center out - Diesel Forum - TheDieselStop.com
Closed Thread
Old 11-08-2009, 05:44 PM   #1 (permalink)
2002 Super Duty. My message center would go out and then come on. Now it has been dark for a month. I searched the posts and read that there was a fix but can't seem to locate it. Thanks, T
bigtbasser is offline
Old 11-08-2009, 05:54 PM   #2 (permalink)
RDG
RDG's Avatar
My Photos: (16)
2000 Ford F-350 Diesel Powerstroke! Trip Computer Fix
TheDieselStop.com Moderator
99.5 F-250 CC SRW
TDS Member since 12.18.99 # 4366
NRA Member
Retired UAW 383
RDG is offline
Old 11-14-2009, 11:00 AM   #3 (permalink)
That was my problem. I removed the foam to remove the screw holding the board. There were two of the flat tiny resistors that were loose. A little solder and I'm back in business. It is such an easy fix I don't know why the Ford manuals don't mention it. They say if the unit is not working and it has voltage replace it. Thanks, T
Old 11-16-2009, 04:01 PM   #4 (permalink)
Same problem, mine goes out, then on, then dim. same year also. Did you do the repairs yourself? How hard to remove the outer console?
2002 F 350 4x4 Crew Cab Lariat
7.3 Diesel 6-speed manual
206,000 miles
All Stock, Possible Chip?
schoolde is offline
Old 11-17-2009, 12:51 PM   #5 (permalink)
kevinj1's Avatar
I did my own one of the hard parts is getting the cover off the console, It feels like its going to break just before the clips let go. also becareful not to drop the resistor if you plan to resolder instead of getting new.
Central, New York
2002 F350 CC,SB Dually XLT, 7.3 Auto, 4X4,102k mi
ZooDad, NAPA 6637,Walker BTM, DIY WVO system '08 mirrors, Much more do
Towing 2011 Flagstaff 8528 BHSS approx 9200 lbs
2001 F-250 7.3L PSD Auto 4X4 SOLD
kevinj1 is offline
Old 11-17-2009, 03:09 PM   #6 (permalink)
It's interesting that your truck, and the OP's truck, supposedly had the upgraded new circuit board. I went ahead and replaced mine with a new updated board instead of resoldering the 5 loose resistors on it. But I was told when I bought the new circuit board that the upgraded circuit board came out during the late 2000 MY and into the 2001 MY. My truck was an early 2000 model.
Makes me wonder if it isn't the vibration that the diesel does that shakes the resistors loose, regardless of which board you have?
I also did the mod to keep my display bright, so that when I have my headlights on (I drive all the time with the headlights on, no DRL), the overhead display doesn't dim.
just my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 11-19-2009, 08:59 AM   #7 (permalink)
grec-o-face's Avatar
My overhead works just fine (for now) but it only shows a few things.
It shows AVG mileage, DTE, Outside Temp, compass.... I think that's it.
When the light hits it just right, you can see the display board has much more in it.
Does anyone else have more displayed?
02 F350
V10 - SCT Tuned
Lariat - Ex-Cab
8ft MM2 HD
03 Mustang GT
Blown/Cammed/Cooled
440/400 11.5 @ 122
(...sold)
grec-o-face is offline
Old 11-20-2009, 04:27 PM   #8 (permalink)
rfishoutofwater's Avatar
fixed mine today thanks to the this board it was a 5 minute fix. Thanks guys
rfishoutofwater is offline
Old 11-23-2009, 02:21 PM   #9 (permalink)
ttmech's Avatar
My Photos: (6)
Whats the fix for keeping it bright all the time and is it too bright at night ?
'04 6.0 F-350 Red, Lariat, CC SB 4x4,power roof & rear slider,K&N ,285-75-16 BFG muds on polished EX wheels, 08 alum. diff cover, SnoPatrol package
ttmech is offline
Old 11-23-2009, 06:15 PM   #10 (permalink)
Do a search on the site. I clipped a wire on the passenger side footwell. I don't want to tell you the wrong wire, so it's better to do a search for the mod (to make sure the 04 is the same wire as the 2000), but it was the light blue with red/burgundy stripe wire. The side panel is easy to snap off and back on.
I don't think it is too bright at night. I like the fact that with my lights on during the daytime, I can still see the display, even in direct sunlight.
Clipping the wire doesn't alter anything else except the overhead display.
short_stuff
Old 11-24-2009, 01:10 PM   #11 (permalink)
Took me longer to drive to father-in-laws house to borrow a soldering iron than it did to fix this. 5 mins start to finish and to think I left the thing not working for 2 months...
TimJ04 is offline
Old 11-26-2009, 11:19 AM   #12 (permalink)
I am missing a couple resistors. Does anyone have info on where or how to get some?
excursionwolfe is offline
Old 11-26-2009, 11:25 AM   #13 (permalink)
dsroka80504's Avatar
I had mine go out on my 01 PSD. Found a place on Ebay that rebuilds the whole thing for about $40, including shipping. Comes with lifetime warranty. I popped it out, shipped it to them and had it back in about 2 days, works great. Was a leak in the cab light that shorted it out and they were still able to ix it. Might be easier than trying to locate resistors.
2011 F350, CC, SB, Lariat Ultimate, Chrome Package, 4x4, FX4, White Platinum, 6.7L
2001 F-250 CC Lariat, LB, 4x4. 205K and Traded in
1996 F-250 XLT Regular Cab, 4x4, 187K. Bartered for construction work.
2010 Cougar 32RLB 5th Wheel - Traded in 1/22/11
2011 Road Warrior 30C Titanium Edition
dsroka80504 is offline
Old 11-27-2009, 09:27 AM   #14 (permalink)
Radio shack is a good place if you have one near by.
This is from the link in the second post:
"These resistors are not soldered in very well, and they are subject to enough heat that they weaken the solder joint and occasionally FALL OFF! If you find yours is missing the SMD resistor, or the resistor is laying in your tray, it is OK to re-use it. It is NOT DIRECTIONAL. If you lost your original, you can use a standard style resistor. The 680's are 68 ohms. I had to replace one as pictured."
I bought a complete new oem board for the piece of mind rather than trying to repair my board.
short_stuff
Old 02-20-2010, 07:29 PM   #15 (permalink)
Is anyone having trouble viewing the above link?
Matt M is offline
Closed Thread
