1999-2007 General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Pull the release lever and pull up on the park park by hand, or you could try setting the park brake then pull the release lever rapidly. If i pull the release lever on mine too slowly the light will stay on so maybe yours is the same way.
2002 F-350 Crew Cab, DRW to SRW conversion, 6spd, 5'' lift, 16x8 Ultra chrome wheels, 35'' nitto terra grapplers, Rough Country dual front shocks, Bully Dog air & pre filter, Autometer Cobalt pyro & boost gauges, 4'' downpipe with 5'' exhaust,
I have to reset the brake and release it again, sometimes 2 or 3 times, to get it to release.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
I do not believe that it is the switch. Because when it is fully released the light does go off. When the light is on I can feel the E brake dragging. I believe it is the mechanism binding or dragging somehow.
Found the culprit, The rubber bumper on the top of the foot lever that hits the switch is damaged, did a temp fix, but that isn't likely to last much longer than a few weeks.
I have the opposite problem.......my light won't come on unless I fiddle around with the sensor at the top of the release. So every time I want to use my AIC or let the truck idle up in the cold I have to poke around until it comes on.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
