Part # for grease? - Diesel Forum - TheDieselStop.com
Old 10-10-2005, 10:43 PM   #1 (permalink)
Part # for grease?
Does anyone have the Ford part # for the teflon grease that is used for the slip yoke on the the rear drive shaft? I have used it on both my truck and it fixed the driveline clunk. I do not have any more and need to help a buddy with his. Thanks.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 10-10-2005, 10:57 PM   #2 (permalink)
My Photos: (21)
Re: Part # for grease?
Are you talking about PTFE ?
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 10-12-2005, 01:23 AM   #3 (permalink)
That looks like it. I had the bigger can. I had just enough to do the driveshaft on my X. Is this stuff available at the dealer? And does it contain teflon or something like that? I guess the smaller tube would be enough for one driveshaft. Correct?
99.5 F250 4x4
2000 Excursion 4x4
mmsafd is offline
Old 10-12-2005, 01:25 AM   #4 (permalink)
klhansen's Avatar
My Photos: (169)
Driveshaft spline lube
D2AZ-19590-A for 1 lb.
XG-8 for 3 oz. (probably enough for the lifetime of one truck)
Hard or no-start? Check Here
klhansen is offline
