Passenger Turn Signal - Diesel Forum - TheDieselStop.com
Old 08-11-2006, 07:34 PM   #1 (permalink)
Weird thing going on, when I click the turn signal up for passenger signals it doesn't do anything, however if I just hold the stick up (Not locked) both signals flash fine? I've checked both bulbs, I have checked fuse 18. Could it be the turn signal stalk switch?
2005 4x4 f350 lariat dually 6.0
4" superlift, MBRP 409 cool duals, autometer phantom ii gauges, riderite air bags w/on board compressor,amp research auto steps, S&B intake for pulling a 2004 Weekend Warrior SLC3705 5th wheel
rampinator is offline
Old 08-12-2006, 09:58 AM   #2 (permalink)
NCHornet's Avatar
Re: Passenger Turn Signal
Yes, the switch in my F150 went out. I would have to hold it in a certain position to get it to work.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 08-16-2006, 12:58 AM   #3 (permalink)
I have a similar problem with the drivers side. It starts clicking really fast like the headlight is burnt out, but it's not, neither is the signal light. The back drivers side light is the only one that comes on. I can turn the truck off few times then back on and it will work. Anyone know what this may be?
2001 F-250 SuperDuty, 7.3L, ex-cab, short box, 6.5 inch Pro-Comp, 37x13.5 Dick Cepek, Edge Evolution BD version, AFE intake
greenedge is offline
