Plugging Diesel engine in at night during cold weather - Diesel Forum - TheDieselStop.com
post #1 of 43 (permalink) Old 12-12-2008, 12:06 AM Thread Starter
What is the 'rule of thumb' about keeping a diesel engine plugged in through the night when the temperature gets below freezing?
trev99SD is offline
post #2 of 43 (permalink) Old 12-12-2008, 12:22 AM
chris u's Avatar
From what I have heard you should be good down to 0 if your glow plug system is working properly. I like to plug mine in for a few hours before start up when its below freezing it just sounds a lot more happy not as much smoke and noise but still need to turn down my programmer for winter.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
post #3 of 43 (permalink) Old 12-12-2008, 12:38 AM
Lightningfast01's Avatar
Depends on the engine, oil, weather.
I never plugged my 7.3 in but it only gets down to single digits at worst here.
Now my 6L is a little cranky especially on 15-40 oil. A few times below 20 I had to cycle the key twice and let the glow plugs warm 40 seconds or so. With 5-40 oil it fires in cold fine. I set my heater on a plug in timer and set it for about 4 hours before starting in above zero temps, 8 hours in below zero temps. The block heater speeds warm up times even if you don't need it for cranking. My cab heat starts working in about two blocks when it is plugged in. Otherwise it is several miles before warm.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
post #4 of 43 (permalink) Old 12-12-2008, 11:14 AM
SmokeyWren's Avatar
My Photos: (45)
It won't hurt a thing except your pocketbook. And the Greenies will frown at you for wasting energy. The block heater draws one KW every hour. Depending on your cost per KWH for electricity, it will probably cost you about ten to twenty cents per hour to keep the block heater plugged in. So a ten-hour overnight will probably cost you between one and two $US dollars.
The rule of thumb to minimize your cost and keep the Greenies from going ape is to use a heavy-duty timer. When the low temp for the night is expected to be between freezing and zero F., turn on the block heater about two to three hours before you plan to crank it. Below zero F. maybe add an hour. With a little experience, you'll learn how much time is required for the expected low temp for the night to achieve the ease of starting the engine and almost-instant heat from the HVAC you are willing to pay for. Of course the Greenies want you to walk to work, so any use of the block heater is a no no.
SmokeyWren is offline
post #5 of 43 (permalink) Old 12-12-2008, 11:16 AM
Get a timer that'll handle 15amp draw & set it for 3 hours. Anything over that & you're wasting money. The heater draws 1kw so it starts to add up after a bit.
Loop the extension cord around your driver's mirror, so you don't forget & take off down the road with it attached.
Make sure your batteries & charging system are up to snuff & you should have no problems down to 0f.
OMC
OMCUSNR is offline
post #6 of 43 (permalink) Old 12-12-2008, 10:11 PM
The "Greenies" can kiss my hiney. I'll plug it in any ol time I want. Those types go right thru me...sorry for the rant
2001 F-350 CC 4x4 XLT PSD.,Pro Comp 6.5 suspension, 325/65/18 Nitto Terra Grapplers,18x10 Ultra Chrome Predator 8s, Trenz Grill,AMP Research Power Steps,X-Monitor,BD Pressure-Loc,SCMT,4 in MBRP Stainless exhaust,Tru-Cool Max,AFE Magnum Intake,Wicked Wheel,BRPV,203* stat,Western Diesel Turbo BrakeIII,Sonnax/Tri-springs,1400watt Pioneer/Polk Audio/Fosgate stereo, pre-pump & tank mods,ORU diff covers,acetoned badges,zoodad mod,heater core bypass,Friends of Oceano Dunes supporter, American Sand Association supporter. KEEP THE DUNES OPEN!!!!!
98 Jeep TJ, 5.7 HEMI/545RFE, RE 4.5 LA,35in MTRs,JB Conv.231JHD,G2 D44, HP 30,ARBs,4.10s, Gen Right Alum. fenders, Premier Power Welder, Warn 9.5 CTi, LoD bumpers,LED lights.
sduncan is offline
post #7 of 43 (permalink) Old 12-13-2008, 07:38 PM
olddieseldude's Avatar
My Photos: (16)
I have mine set up on a timer (3 hours) as mentioned by others. I went one step further and put a battery tender from NAPA on my batteries that is on the same plug as the block heater. This way the batteries get a little warm up too. I only plug it in below freezing and really just so that I get defrost quicker, my truck is outside 24 -7 so it helps a lot.
RickN
(mods listed in comments under photo in above link)
olddieseldude is offline
post #8 of 43 (permalink) Old 12-13-2008, 10:38 PM
I thought you could overcharge batts in real cold weather...
post #9 of 43 (permalink) Old 12-14-2008, 12:14 PM
bobsherrie's Avatar
Can't overcharge a battery in any weather IF you use the proper charger, like a Battery Tender/Battery Minder. Or an automatice style charger. They will sense battery condition and cut off.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
post #10 of 43 (permalink) Old 12-14-2008, 12:40 PM
SmokeyWren's Avatar
My Photos: (45)
You can overcharge a battery in any kind of weather, if you use a cheap battery charger that's not "automatic". The good automatic battery chargers cost more in the short run, but they won't ruin your battery by overcharging it.
The battery minder type chargers (trickle chagers) are almost all automatic, but even if pure manual they charge at only a tiny charge rate so they won't overcharge much, even after 24 hours or so on a "full" battery. I keep one plugged into my RV battery all the time, with no problem of overcharging.
post #11 of 43 (permalink) Old 12-15-2008, 07:46 PM
ArchitectandBuilder's Avatar
As said, I have a timer on Rach's Excursion, set for 3 to 4 hours depending on the temp.
Mine on the other hand, I have plugged in all night at low temps. Sorry to the greenies, I have no idea when I may be toned out in the middle of the night.
Barrett
Mine: 2003.25 F-350 Lariat CC, SRW,8' bed, 6.0, Torqshift, Toreador Red, Tan Leather, Trailer Tow, Rhino-Liner, Dee-Zee Platinum Box, Adjustable Pedals, Heated Seats, 6 Disk Changer, DVD, 04 Keypad, AIC, 20% Tint, Escort 8500 X-50, Magellan Meridian Color Gps, BFG 285r17 KM2ís. DPPI Dual SS Turbo Back Exhaust,"X" Springs,Issopro EV Pyro,Trans,Boost,Oil Temp, Water Temp, Volt Meter, Air Press., Viair 550C AC, 26" & 29" Hadleys, 2006 Front End, Chrome Tow Hooks, Warn 16.5ti, Billet Cummins Killer Badges, Int. VT-365 Badges.
Diesel_Mom's: (Redhead): Goodbye 2001 EX, Thanks for 4 years. Brand Spanky New 2005 Eddie Bauer Excursion, DVD, Toreador Red</font> , 6.0L Powerstroke, all options including (3) children, (1) 95# Golden Retriever, Goodyear Wrangler 285 MTRs.
ArchitectandBuilder is offline
post #12 of 43 (permalink) Old 12-16-2008, 11:44 AM
7.3 is a mighty motor, it loves to be plugged in, when its cold like everynite in winter in wisconsin here when its below 20 ill plug mine in at nite and will stay plugged in alll nite till i leave in the morning, the motor LOVes to be warm all nite
1999 7.3 liter, 190k, AFE stage 2 intake, Edge juice with attitude, homemade 4 inch to 5 inch slash cut stacks, Garrnett 88mm ball bearing turbo
7.3torquemaster is offline
post #13 of 43 (permalink) Old 12-16-2008, 01:09 PM
Electric draw
I've read the forum replies on the electricity draw per hour (just to plug in) and I've read the forum replies on whether or not you can remote start the car while it's still plugged in...
Anyone know what the draw is when starting the car and it's still plugged in?
Many thanks!
Dae
Daemona is offline
post #14 of 43 (permalink) Old 12-16-2008, 02:59 PM
SmokeyWren's Avatar
My Photos: (45)
As the motorboat people would say, the block heater is 120 volt "shore power", and has nothing to do with the 12-volt automotive electrical system that powers the starter.
So a remote starter should use the 12-volt batteries in the truck, and has nothing to do with the extension cord that runs to the electric plug in the garage to heat up the block heater.
That extension cord to the block heater is going to be drawing about 1,000 watts before, during, and after you crank the engine with the remote starter.
post #15 of 43 (permalink) Old 12-16-2008, 04:15 PM
Hmmmmm.....I keep my truck in the garage, which happens to be right at 40 degrees when it was below zero the last couple days/nights. But hey.....if it pisses off the greenies, I might just plug it in for the heck of it.
The forecast here shows a high on Sunday of 4 degrees and a low of -12. You guys up north are REALLY gonna feel it. Better get ready to plug it in now. Perhaps we all should have a National Plug-in Day for the greenies.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
