General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Pop when replacing steering gear airbag light on. Is it the clockspring
We had to replace my power-steering gear out in the field yesterday. After fitting the steering shaft onto the gear I heard a pop the next time I turned the steering wheel, and then when I started the engine the airbag light started flashing and then stayed on steady. My brother said maybe we turned the steering shaft too much and "broke the clockspring". He has heard of this but didn't know what all it involved. I hadn't heard of the clockspring before at all and am hoping someone out there can help us out.
2000 F-250 7.3L PSD, 6-Speed, 131.5K+, 4-Puck button clutch, TS Perf. 6pos Chip, Western Diesel~Ram Air, Gauges {Boost & Pyro}, AFE Stage 1, 4" Turbo back exhaust, ITP Over-Boost Eliminator, Cyclone Fan Controller, 4" Lift, BF Goodrich A/T 35x12.50x16.5, Eagle Alloy Rims, GoRhino Brush Guard, etc. Check it out here~ Cardomain mod list & pics
Sounds like you did. You aren't suppose to let the wheel turn at all with the shaft disconnected. Is your horn and cruise dead too? Sounds like you ripped the clockspring wire ribbon. You can replace it, it's not that bad if you have a steering wheel puller. It is located behind the wheel and is a plastic ring shaped thing with a couple plugs going into it. The new one will come taped down to prevent turning, don't untape it untill it's mounted in the column. Good luck
Values are typical and may vary by 10% depending upon current altitude, accessory operation, engine load, operating time, temperature, and vehicle speed.
OK thanks, I'll check the horn & cruise. It's dumb luck I guess, but I replaced the power-steering gear when I first got the truck back in '06 and didn't run into this. Oh well live & learn I guess!
To replace a steering gear you should start with the wheels straight ahead, tie the steering wheel in place before disconnecting the shaft, AND put the new steering gear in with it centered before reconnecting the shaft. If the wheels are turned when you reconnect the shaft, the clock spring will break on the first turn. Kind of like an old windup toy -- crick, crick, crick, twang!
When you replace the clock spring, the new one will have a tab that keeps it in the center position. Don't pull that out till you have it installed (again with the steering wheel centered and wheels straight ahead).
before you start to replace the clockspring, disconnect both batteries and let it set for a few minutes. dont want an accidental airbag deployment in your face close up. that would sting a little.
2001 crew cab 4x4 7.3 straight pipe, oil crossover kit, wheels and tires(mt classic II's with 285/75/16 terra grapplers) 2 tv's, 2 10's
89 mustang gt, intake, heads, nos, gears, etc.
86 mustang trunk car, built 351 windsor, c4, built 8.8 rear, lakewood shocks and struts,eibach springs, too much too list, mostly race, maybe go get some milk with it
92 mustang gt convertible, triple white, exhaust, pulleys, just a clean driver car
05 scion xb, wheels, tint, 3tv's
on another note, how involved was the steering gear replacement?
04 F350 lariat, PSD, AT (the toy hauler) Edge Juice Platinum w/attitude, Silverline T409 Dual 4" Turbo back exhaust w/no muffler, AFE Stage I, Alpine W205 DVD player/nav. ARP box on the shelf
06 International 4300 DT466/Allison Ramp truck. (Tows others' toy haulers)
85 Oshkosh P19A Aircraft Fire Truck Cummins NTC400/A5 - the daily driver while I'm here in Iraq. Guess the Marines are trying to force me to be a Cummins fan!
*2 91 SHO's* *1 97 SHO*
