Popping noise toward front of bed - Diesel Forum - TheDieselStop.com
Old 11-11-2009, 11:33 PM   #1 (permalink)
I drive a 2001 F-250 and when I go over a bump, say a curb when coming out of a parking lot, at a low speed, I get a loud pop under the truck on toward the outside maybe near the front of the bed?
Any ideas?
2001 F-250, PSD, 4X4, Crew Cab, Lariat, 3.73 Limited Slip, Towing/Camper Pkg, AIS filter, '02/'03 headlights & clear corners, Harpoon Mod
BucknBass is offline
Old 11-15-2009, 10:30 AM   #2 (permalink)
Probably one or more of the chasses bolts from the frame to the cab are loose. This was a common issue.
('99 F250 XLT 4x4-SOF SC LWB SRW AT 3/98 Build XLE4), diablo 78 hp, ADPerformance 2 stage Propane, Detroit No-Spin lockers-rear, ARB lockers-front, diablo $hift valve, tricumulator spring pack, AICM, Amsoil air filter, BFG 285x75 MT's
BCate is offline
Old 11-16-2009, 11:59 AM   #3 (permalink)
Any ideas?
I had the same problem, most noticable when the truck was twisting over uneven ground. It was my swaybar bushings. Got a new set from summit and the problem went away. Grag your swaybar, I am guessing that you have one, and see if there is play or looseness. I was also told that you can disconnect one of the drop rods and if the noise goes away this is how to tell if the bushings are bad. I did both front and rear for around 70 bucks total.
2002 F 350 4x4 Crew Cab Lariat
7.3 Diesel 6-speed manual
206,000 miles
All Stock, Possible Chip?
schoolde is offline
