PDL Rebuild Works Awsome
Just want to thank [FONT='Verdana','sans-serif']wittmeba et. al. for the post on the [FONT='Verdana','sans-serif']power door lock [/FONT]actuator rebuild. I thought I would loose my mine without the PDL working. Rebuit mine and they work better than new. Took the time to lube everything and all the window drives at the same time. [/FONT]
[FONT='Verdana','sans-serif']The resistor is actually and carbon thermal sensitive resistor that is designed to prevent motor overheat if someone lays on the lock switch. The problem is that these units have a shelf life. So even if you get ‘new’ ones, if they are old an old fabrication date, they will fail soon after you put them in.[/FONT]
[FONT='Verdana','sans-serif']I wrapped mine in al foil on rebuild. Works great. No $$ to fix. Takes about an hour to pull the unit apart and repair. Worth the time given the cost of new units that will fail in time. [/FONT]
[FONT='Verdana','sans-serif']Thanks to all for this post and the detailed info. I have photos of mine if anyone wants them. [/FONT]
[FONT='Verdana','sans-serif']B. [/FONT]
2000 F-250SD 7.3PSD, 4x4, Auto, 3.73LS, SuperCab w/8' bed, elec 4WD, Special Towing pkg, Off Road
