General QuestionsGeneral questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
I am traveling a few hours on Wednesday to look at a '99.5 2WD SuperCrew Super Duty with a 6-speed and 102k miles. This is my first diesel and I want to make sure I know what to look for/be aware of. Any tips are appreciated-
After reading this sight, I'd get an oil sample and have it analyzed before I bought used. Seems to be highly recommended by most here. Good luck on your new truck!
Kirk
Keep the shiny side up, and the smoke pourin out the back![img]/ubbthreads/images/graemlins/cool.gif[/img]
04 F250 Ext Cab/6.0 PSD/Torqshift/3.73/FX4/LB/Dark Shadow Grey/Billet Grille/AIRAID filter/MBRP Turbo back stainless dual exhaust/30K B&W Hidden Hitch/Electronic Brake Controller/Superchips microtuner/Weatherguard ADP toolbox/Linex/
Man...I didn't save the webpage, but one of the other threads gave a webpage of an analysis lab. Lemme see what I can find.
Kirk
Thanks for the tip...what kind of shop would analyze that? Any regular parts house, or does it have to be specific?
Ok..this is the lab one of the other guys in another thread was referencing. I guess it's a mail in thing that he uses. Anyhow, I'm guessing someone at a local diesel shop should know someone local if they are available. I can't speak for these guys, but someone else recommended them. Link is below.
Blackstone Labs is the one used the most for oil analysis on TDS and they are pretty quick if you give them your Email address to send the results to. This Thread will give you some more things to look at especially the dusting issue with these PSDs.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Thanks Kirk and FMT. I don't know about the oil sample at the time, but I know I can check for dusting. If there is a little bit of sand/dirt in there, is this something I should completely back away from, or know about the issue and fix it?
It all depends on the severity of the dusting but it can get real expensive to repair correctly. Turbos, piston and rings worn cylinders and the list goes on.
FMT
Is the dusting caused from the airbox not having the recall performed? Can I take the VIN to any Ford dealership and find out if it has been done? Also, where is the cavitation coolant added?
