Radio ? - Diesel Forum - TheDieselStop.com
Old 06-16-2006, 07:01 AM   #1 (permalink)
Radio ?
Just picked up my new 06 - 6.0 PS yesterday. How do you remove the radio from the dash?
2008PSD 4x4 F250 SRW
(Sixth Ford Diesel. All great trucks)
2004 Fleetwood GearBox (14,000 lbs)
1999 Harley Ultra Classic
Boneyfinger is offline
Old 06-16-2006, 07:06 AM   #2 (permalink)
Re: Radio ?
You have to pull the front part of the dash off. It's a pain, but take your time and get all the snaps and connectors off. Don't force anything. Then there will be 4 screws to remove the radio. There are some pictures on the signature link.
Rick
2006 F250 King Ranch FX4 - (Build date Sept. 2005)
6.0L (Engine Build date Sept. 21 2005)
Dark Copper w/ Beige accent
Short Bed, Crew Cab, Sun Roof, Power Rear Window
18" KR wheels, Camper Package, Tow Command
Mods: Shaker 500 Stereo, Alpine MRV-F450 amp, Line-X, Edge Insight, MBRP 4" Turbo Back Exhaust, Diesel Site Coolant Filter, Blue Spring upgrade, Removed Ford Gold Coolant, Fuel Pressure Guage
ralderman is offline
Old 06-16-2006, 10:58 AM   #3 (permalink)
FamilyRide's Avatar
Re: Radio ?
Why not use the radio rwmoval tool and just slide it out? Although, I have that dang tool and can't seem to figure out how to get it to work so I can try to fix a squeeky rattle thing in the dash/radio. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Autozone sells them for about $5.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 06-16-2006, 11:53 AM   #4 (permalink)
Re: Radio ?
05/06 need to remove the dash like ralderman said
1olddog2 is offline
Old 06-20-2006, 04:59 PM   #5 (permalink)
Re: Radio ?
For the aux on the stock radio is it 2 rca connections on the back? I am wanting to hook my satelite radio up to it instead of the m transmitting. Any help would be apprieciated. THanks
2006 F350 Crew Cab Short Box
6.0L Powerstroke w/ 5 speed auto
Dark Stone/Arizona Biege
20" Stock Rims w/325/60R20 BFG AT's(winter)
17" Eagle Alloy 137 w/33" Nitto Mud Grapplers
Rev-Tek Leveling Kit / Bilstien 5100's
Spray in Box Liner, VentVisors
Chrome Nerf Bars
JBL 6x8 Speakers(Front and Back)
S&B Intake, EGR Cooler Delete
Muffler Delete with 5" S.S. Tip
Lost my cat somewhere
ABFord is offline
Old 06-21-2006, 01:45 PM   #6 (permalink)
Re: Radio ?
The best way to do it is get an can adapter from P.I.E (presicion interface electronics). If you search the web you can find them. This converts the can bus to 2 rca for plugging stuff in. I haven't tried one yet, but that is what I intend to use.
2006 f350 King Ranch Dark Copper with shift on the fly 4x4, power moonroof, tow boss, tow command, fx4, 6 disc cd, adjustable pedals, dual altenators, upfitters switches, reverse aid sensors, snowplow package.
SOLD 89 F250 7.3 IDI XLT extended cab 2wd 5spd 450 read end and springs, set up for towing. 220,000 miles, my first diesel. Tows my race car like there is nothing behind it. lives in Kingston NH
landis_rogers is offline
Old 06-21-2006, 02:11 PM   #7 (permalink)
Re: Radio ?
You can remove the ashtray & slide assembly, remove the trash bag hook (or whatever that thing is) and then you can reach up behind the radio to plug in a PIE or whatever you have. Search this site for the exact audio components/adapters. I used and adapter, a 3 source selector and an iPod adapter/charger for SM, iPod, and free pair of inputs for whatever comes along next.
If you want I can check on exact components & source when I get home tonight.
<font color="red">
2006 F-350 PSD SRW SB; Pullrite 16k Slider; Westtach: EGT, Boost, Oil Pres, Tran Temp, Volt; XM; 2 meter; CB; iWay 500C; iPod. 2006 Sunnybrook 32BWKS.
</font> KE4DMG
Larry Marola is offline
Old 06-21-2006, 04:37 PM   #8 (permalink)
Re: Radio ?
Larry Marola; I would like to have the component &amp; source list. It would save me a lot of time doing the research, Thanks.
Old 06-23-2006, 09:05 PM   #9 (permalink)
Re: Radio ?
I have A 2005 Dually and would like to have an RCA conector from the Aux. switch,what is the best way to do this,and where can I get it ?
Thank you.
stari is offline
Old 06-23-2006, 09:16 PM   #10 (permalink)
south_paw's Avatar
My Photos: (16)
Re: Radio ?
All the info you need is here in a previous post of mine(scroll down a bit to my post) Click here
2005 F250 6.0 PSD CC Auto, Dk toreador red/Ariz beige,Lariat Luxury 4x4 SB,TT Mirrors,Camper PKG,Roof lights,ADJ pedals,REV aid,Trailer hitch,TOW COMMAND,ESOF,PWR rear window,3.73 posi,SIRIUS SAT radio. Built 08/09/04
2005 F250 SIRUS RADIO
2002 BUYBACK bad paint F250 7.3 PSD Auto CC Lariat 4x4 SB, TT mirrors,Camper pkg,Grille insert,Hood shield,Tow pkg,Adj pedals,Shift on fly,Trailer brake,Spray in bedliner,Dk highland green w/tan.
2002 F250
south_paw is offline
Old 06-23-2006, 09:34 PM   #11 (permalink)
Re: Radio ?
In the morning I will have to look at my radio, but I don't remember seeing the AUX option on there anywhere (6 Disc in dash CD) but if that is the case with simply plugging it into the back of the stock radio I may have to look into getting a XM or Sirrus reciever.
2006 F-250 Lariat PSD Fx4 Shortbed Extended Cab, 4" MBRP Cat Back (have the DP just not installed yet), Fumoto Valve, Viper 160XVL Remote start
Engine born on date- 5/13/05 (a Friday no less)
brnscofrnld is offline
Old 06-24-2006, 07:28 AM   #12 (permalink)
Re: Radio ?
Boneyfinger,
Check out Log Jam Electronics .
I got a PIE FRD04-AUX; Soundgate AUX3 Multiple Aux Input Switching Interface, and a Blitzsafe UII Universal iPod Interface. Just be sure to get the right model AUX input for your year truck.
Old 06-24-2006, 10:53 AM   #13 (permalink)
Re: Radio ?
Boneyfinger,
One more thing. I just realized this after running a few errands this morning.... You'll want to use the same delayed power source as your radio for the aux add-ons. I didn't at first them went back and rewired everything. I actually used the delay power to the radio as a signal to a relay I put in that pulls directly from the battery to handle some other things I wanted delayed too (XM, CB, 2-meter radio, cell phone chargers, GPS).
<font color="red">
</font> KE4DMG
Old 06-24-2006, 11:36 AM   #14 (permalink)
Re: Radio ?
Unfortunately, everything that I have found on the Internet that will connect an Ipod to our 2006 Super Duty radios will not work with the steering wheel controls and will not display on the display screen. We need something that will operate an Ipod or XM Radio through the factory controls. This animal may not be available yet. There is a market for this product if someone will just develop it. I am about to install my aftermarket radio with XM radio and Ipod with remote control into my new truck I will need to contact Crutchfield and get the new wiring harness and be done with it. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
