Radio stays on....99.5 F250 - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 10-16-2006, 09:19 AM Thread Starter
It started a week ago. I was on a 3 hour road trip and the battery light started flash while driving. Also the battery volt meter started to slowly drop. Once I reached my destination I tested the batteries and they were low. SO apparently I was running off of the batts. I charged them back up and headed home the next day. Once again driving off the batts. Once in town I I pulled the alternator and had it tested. It failed so I swapped in a new one. Problem solved. Now, one week later I walk outside and the keyless remote won't work and the factory radio is on! No key in the ignition or anything. I used the key to get inside and and the truck starts. I check the guages and no battery light or low volts. I'm stumped. Never seen a radio stay on with the key out of the ignition and the keyless doesn't work. Any input would be most appreciated.
CJBrad is offline
post #2 of 4 (permalink) Old 10-16-2006, 01:56 PM
doczenith1's Avatar
My Photos: (11)
Re: Radio stays on....99.5 F250
I had a similar thing happen to me last fall, only I was out duck hunting. The radio would stay on even when i turned off the truck. Turned out that a relay from my car alarm got crushed and it shorted out some part of the trucks computer/brain. The dealer spent 10 hours tearing apart the dash and reseting the computer stuff. I got off lucky and they only charged me $200. I then went to the car alarm place and had them re-hook up the car alarm and cut me a check for the $200 since they didn't properly install the alarm system by placing the relays in a safe location.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
SOLD
2003 Mustang SVT Cobra, black convertible. - 6/2007 - 9/2013
SOLD: 2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #3 of 4 (permalink) Old 10-16-2006, 02:24 PM Thread Starter
Yikes....I did briefly short the alternator hot lead when removing the old alternator. But the problem didn't show up till a week later. I wonder if I fried something...Can I reset my computer by disconnecting the batteries for a set amount of time?
CJBrad is offline
post #4 of 4 (permalink) Old 10-16-2006, 05:36 PM Thread Starter
Problems getting worse. Now with the key out of the ignition I can turn the radio on a nd the AC. Every now and then I can hear what sounds like a relay switch going on and off. I pulled the fuse panel off trying to locate the sound. If I reach through the small hole on the right side of the fuse panel compartment, I can feel the section that is switching on and off. Could this be the ignition switch causing this or something else?
CJBrad is offline
