Rear Brakes Torque Spec - Diesel Forum - TheDieselStop.com
Old 10-16-2009, 12:36 PM   #1 (permalink)
My Photos: (10)
I very much need the torque specs for the REAR brake caliper mounting bolts and the slide pin bolts for a 2001 F250. I used the front brake specs and sheared a slide pin bolt.
I have a few hours while I wait for 2 new bolts, but I need to get back on the road.
2001 F250 4x4 CC SB PSD, Auto w/ 186k as of 07/09, dual alts, ISSPRO guages under dash, Bilsteins, OilGuard bypass oil filter, Rancho 5406 SS, AIS, 3 1/2" Walker BTM, WD-40 fixed my "door ajar light", aftermarket electric door locks (3 done, 1 to go), A/C heater bypass, CCV reroute, IAH delete, rebuilt tranny with FTVB (mechanical diode went out @82k). Pre-pump/in-tank mods w/ 75 micron pre-filter, 203 degree stat and coolant filter, new water pump @ 100k.
rocinbaja is offline
Old 10-16-2009, 12:45 PM   #2 (permalink)
ford_doctor's Avatar
Disc brake caliper pin bolts — F250/F350 with Ford and Dana axle 27 LB/FT
Rear wheel disc brake adapter bolts — F250/F350 with Ford axle 150 LB/FT
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is offline
Old 10-16-2009, 07:03 PM   #3 (permalink)
My Photos: (10)
Thanks, that is what I needed. Didn't shear the bolt this time...
I used three quarts changing the brake fluid. Does that sound about right?
