I think I'll probably need calipers because...ready....those old ones may be shot.
I would do more than pads if needed, I'm actually gonna take a look at what I'll need tomorrow. But considering FOMOCO is the only place to get the caliper BRACKET, and they charge $100 for that alone, it's smarter to have the piece of mind of new calipers, brackets, AND pads for $120.
And, the Excursion IS a Super Duty, so that's why we're posting here. It's on the F250 frame and shares just about all parts w/ 250 and 350... Plus, Excursions had the 7.3 AND 6.0 motors, so more specific info is available under the 7.3 forums. I suppose I could use the Ex forum for general stuff, but no moderators have complained thus far.
And yes, the SD forums get a lot more traffic as well.
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
