Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 04-01-2007, 09:56 AM   #1 (permalink)
Rear diff fluid capacity
What is the gear oil capacity for my rear diff? I can't seem to find the right info in my manual. It's an '02 F350 with the limited slip.
Thanks all,
Peter
2002 F350 Superduty 7.3 PSD 4X4 Crew Cab Longbed
F350Peter is offline
Old 04-01-2007, 10:19 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: Rear diff fluid capacity
You don't mention which F-350 you have, and it makes a difference.
If you have single rear wheels (SRW), then your Ford "Sterling" diff holds 6.9 pints of gear oil. But if you have dual rear wheels (DRW), then your Dana 80 rear end holds 8.3 pints.
Ford says to add friction modifier additive if you have limited slip. In one place they say 4 ounces, and in another place they say 8 ounces. I wouldn't add any until after you button it up with the fresh lube, drive several miles, and then do a figure-eight test on dry clean parking lot pavement. If you don't get the clatter/chatter/racket from the rear end during full-lock turns, then you don't need any friction modifier. If you do get the racket (caused by a tire dragging around a sharp turn instead of rolling), then I would add one ounce at a time and retest.
Too much friction modifier will turn your LS rear end into an open axle. So that's why I would add one ounce at a time instead of just dumping in the whole 4 or 8 ounces.
SmokeyWren is offline
Old 04-01-2007, 10:32 AM   #3 (permalink)
Sorry about that....it's a SRW with the Sterling diff. Does the 6.9 pint capacity include the extra ounces of the friction modifier, or is that in addition to the 6.9?
Thanks for the info!
Old 04-01-2007, 12:27 PM   #4 (permalink)
Smokey is absolutely correct as usual...I added 4 oz of the modifier and now have the equivalent of an open.... [img]/ubbthreads/images/graemlins/eek.gif[/img]Had to use 4 hi to get out of DD's flat driveway last week with one wheel on ice [img]/ubbthreads/images/graemlins/eek.gif[/img]. Got a bit of seepage around the housing so may change it again and no additive this time.
Ian
2004 PSD F350 Lariat 4X4 CC long box Arizona Beige , AIC, FX4 heated seats, adjustable pedals, power rear slider, towing pkg/ receiver, power Towing mirrors, camper pkg,reverse sensor, 3.73 LS, torqueshift, bedrug, born on Dec 3 2003. Towing 2005 Cougar 5th wheel 285 EFS with a bell and two whistles.
ikidd49 is offline
Old 04-01-2007, 02:51 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (33)
6.9 pints (3.3L) is the total capacity. I would pour in 3 quarts (or 3 liters if you're in Canada) then test it and determine if you need friction modifier. After you have the right amount of friction modifier mixed in and tested, then top it off with diff lube.
