Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-05-2009, 11:51 PM   #1 (permalink)
which rear-end ratio?
Looking to pull a trailer weighing 25,000-30,000 #. My '96 Powerstroke with 3.55 gears doesn't want to pull the load. My question is would 3.73 gears be adequate so that I can still get half-way decent mileage or will I need to go to 4.10 gears? Thanks.
Ron Bickel is offline
Old 01-06-2009, 06:32 AM   #2 (permalink)
Rich_Kimball's Avatar
Ron, am guessing you are not serious right? Go get a bigger truck for that load as not even 4.10 will be enough. Neither are your brakes!
Happy trails,
Rich Kimball
2000 F350 XLT CC LB SRW 6spd 4x4 Toreador Red
'08 Center Console,Ranch Hand Grill Guard, SBC ConO clutch,DP Tuner (60T,80E,120R),Gauges,Ford AIS,Walker BTM,AIH delete,HPX Oil Crossover, Wicked Wheel,TurboMaster WG Contoller,Riley BRV+,Riley Boost Boots,EBPV Gut w/mod. pedestal,IH Bellowed UpPipes,Final Charge ELC coolant w/heater bypass,Riley Coolant Filter,Ford AIC,Centramatic Wheel Balancers,115gal Aux tank,Firestone airbags w/cab control. Oilguard Bypass Filtration,DFA 'Cross Connect' Fuel Lines
Rich_Kimball is offline
Old 01-06-2009, 03:24 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (42)
Your truck is rated to gross 16,000 pounds max combined weight (GCWR). If you had the 4.10 axle ratio, the rating would go up to 20,000 pounds combined weight. Nobody with good sense would attempt to gross 37,000 pounds by pulling a 30k trailer with a 7k pickup that has a 20k GCWR.
Not even a 2008 F-450 pickup is rated to gross more than 33,000 pounds combined weight.
An F-550 with 4.88 rear axle ratio is rated to gross 30,000 pounds combined weight if it has the high capacity towing option. But to gross 37,000 pounds requires a properly equipped F-650 or F-750.
Another problem is hitch weight. Unless you are talking about a wagon-type grain trailer with almost no hitch weight, you're going to severely overload the rear axle and rear suspension and frame of your tow vehicle. A gooseneck trailer with 18 percent hitch weight when loaded to 30,000 pounds will put 5,400 pounds of road-hugging weight on your truck. So you'll wildly exceed the GVWR of the tow vehicle.
So simply changing the rear axle ratio in a pickup is not going to hack it. You need a much bigger truck to safely tow a trailer that weighs 30,000 pounds.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is offline
