Rear Leaf Spring Codes - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 09-18-2007, 02:43 PM Thread Starter
My 250 springs feel a little soft and would like to upgrade to heavier ones. Does anyone know what the rear spring codes are for the different trucks (250, 350)?
Thanks,
Mark
2002 F-250 4x4 XLT SC SWB Dark Shadow Grey, PSD, 6-spd, 3.73ls, Camper, Off-Road, Advanced Security Group, Power TT Mirrors, Rear Sliding Window, B&W Turnover Ball Gooseneck, Putnam XDR class 5 Hitch, Husky Liners, Lariat Wheels and 265/75r16e Michelin LTX M/S, Bilstein Shocks, 4" Turbo Back Exhaust with Aero Turbine Muffler, AFE Stage 2 Intake with PG7 filter, Pacbrake PRXB Exhaust Brake, B Code Rear Leaf Springs from a 2004 F-350
h2oskiier222 is offline
post #2 of 20 (permalink) Old 09-18-2007, 04:26 PM
SmokeyWren's Avatar
My Photos: (45)
Re: Rear Leaf Spring Codes
For 2002,
A = 6,084 pounds @ground = F-250
B = 6,840 pounds @ground = F-350 SRW and some F-250s
C = 8,250 pounds @ground = F-350 DRW
D and E are for chassis cabs and won't fit a pickup.
A, B, and C are all the same width and length. The difference is in the thickness of each leaf. You can put code C rear springs on your SRW if you prefer the ride of an empty dumptruck.
SmokeyWren is offline
post #3 of 20 (permalink) Old 09-18-2007, 04:39 PM Thread Starter
Thanks a lot Smokey! Now I just need to look at my truck and see which springs it has. More than likely it sounds like the A codes are on there.
Thanks,
Mark
post #4 of 20 (permalink) Old 09-18-2007, 05:26 PM
LOL @ dumptruck
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, 6.0 Trans cooler, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
2008 H+H 24' CL series V Nose Car Hauler
Blk88GT is offline
post #5 of 20 (permalink) Old 09-18-2007, 10:12 PM
Smokey, I have an 03 F250 CC and looked at the door sticker and it said SPR UP? The sticker is on the front drivers side door jam. Could this be correct or am I looking at the wrong sticker?
2003 CC SRW SB Auto 3.73
Mods:
REAR Air Locker
Kenwood DNX 7140
ISSPRO A Pillar Gauges
Femoto Valve
Edge Insight CTS
dieselhappy is offline
post #6 of 20 (permalink) Old 09-18-2007, 11:40 PM Thread Starter
So for the record I looked at my door sticker and it says SPR VA...I am assumming that this means v springs in the front and A springs in the rear, so I need to find some B springs for the rear.
post #7 of 20 (permalink) Old 09-18-2007, 11:44 PM
SmokeyWren's Avatar
My Photos: (45)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dieselhappy</div><div class="ubbcode-body">Smokey, I have an 03 F250 CC and looked at the door sticker and it said SPR UP? The sticker is on the front drivers side door jam. Could this be correct or am I looking at the wrong sticker? </div></div>
Code U front leaf springs have been around for years. Ford added rear spring code P during the 2003 model year. All I know about it is in the following info from the workshop manual:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">
Springs codes are listed as a two-part code. The first character listed is for the front springs. The second code listed is for the rear springs. Auxiliary rear springs may also be listed.
Front Springs F-Series
E F81A-5310-EA
F F81A-5310-FA
G F81A-5310-GA
H F81A-5310-HA
I F81A-5310-RA
J F81A-5310-JA
K F81A-5310-KA
R F81A-5310-AAB, 3,600 lb.
S F81A-5310-AAB, 4,000 lb.
T F81A-5310-ABB, 4,400 lb.
U F81A-5310-ACB, 4,800 lb.
V F81A-5310-ADB, 5,200 lb.
W F81A-5310-AEA, 5,600 lb.
X F81A-5310-AFA, 6,000 lb.
Y F81A-5310-VA
Z 2C34-5310-WA
Front Springs Excursion
B YC35-5310-ABC
C YC35-5310-ACC
D YC35-5310-ADA
G YC35-5310-GA
H YC35-5310-HA
S YC35-5310-SA
Rear Springs F-Series
B 3C34-5560-L
C 3C34-5A975-D
D 3C34-5A975-G
E 3C34-5A975-K
J 3C34-5A975-J
M 3C34-5A975-E
N 3C34-5A975-F
P 3C34-5A975-C
S 3C34-5A975-C
Rear Springs Excursion
A YC35-5560-A
</div></div>
post #8 of 20 (permalink) Old 09-19-2007, 12:46 AM
The "P" code springs on your F-250 are rated at 6830#. These are the same exact rear springs used on the on the F-350 SRW and were also standard for '03 and '04 F-250's. I have "P" codes on the rear of my '04 F-250.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
post #9 of 20 (permalink) Old 09-19-2007, 10:24 AM
Thanks for the info it all makes sense now why the rear was not squatting as much when hauling a load.
Mods:
REAR Air Locker
Kenwood DNX 7140
Femoto Valve
Edge Insight CTS
post #10 of 20 (permalink) Old 09-19-2007, 01:32 PM Thread Starter
Okay, so one more question. I found a pair of rear leaf springs at a local junk yard. They are B-codes off of a 2004 F-350 SRW. Are these the same springs that are listed above (6840 lbs.)? Any other advice is greatly appreciated.
Mark
post #11 of 20 (permalink) Old 09-19-2007, 04:32 PM
SmokeyWren's Avatar
My Photos: (45)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: h2oskiier222</div><div class="ubbcode-body"> Are these the same springs that are listed above (6840 lbs.)? </div></div>
Code B and code P rear leaf spring packs are both rated at 6,840 pounds @ground, and are the same length and width, so they will interchange on '99-'04 SuperDuty pickups.
I don't know the difference between code B and code P rear leaf spring packs, but there must be something or Ford wouldn't assign a different code. Would they?
post #12 of 20 (permalink) Old 09-19-2007, 04:40 PM Thread Starter
It doesn't seem like it. Maybe they have a different arch to them or something.
post #13 of 20 (permalink) Old 09-20-2007, 05:49 PM
If the springs are rated at 6800 pounds what is the hauling capacity in the bed?
Mods:
REAR Air Locker
Kenwood DNX 7140
Femoto Valve
Edge Insight CTS
post #14 of 20 (permalink) Old 09-23-2007, 12:13 PM Thread Starter
One more question: I ended up getting a pair of spirngs off of a 2004 F-350; the door on the truck was coded Y for rear springs. What are the weight limits on these? Thanks for all of your help!
Mark
post #15 of 20 (permalink) Old 09-23-2007, 06:54 PM
SmokeyWren's Avatar
My Photos: (45)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: h2oskiier222</div><div class="ubbcode-body">One more question: I ended up getting a pair of spirngs off of a 2004 F-350; the door on the truck was coded Y for rear springs. </div></div>
I doubt it. For 2004, there was a "Y" front spring code, but not a "Y" rear spring code. Here are all the rear spring codes for 2004 model year per the 2004 Workshop Manual:
B 3C34-5560-L
C 3C34-5A975-D
D 3C34-5A975-G
E 3C34-5A975-K
J 3C34-5A975-J
M 3C34-5A975-E
N 3C34-5A975-F
P 3C34-5A975-C
S 3C34-5A975-C
I also checked the 2005 workshop manual to see if perhaps the Y rear spring code was a late addition for the 2004 model year. But there was no "Y" rear spring code for the 2005s either.
