Re: rear pinion seal
I had to replace one on mine at 35,000 miles. When I noticed it was leaking, I did a little research on here and discovered it is a relatively common problem on CC DRW's. Not sure why, but apparently it is.
I got mine fixed under warranty. It isn't supposed to be a tough job, but if it isn't done correctly, it can be a pain. When they did mine, they replaced the seal and suddenly, I had a bad vibration. They ended up replacing the driveshaft, yoke and another seal before they finally got it right. I suspect they damaged the driveshaft and yoke doing the job the first time, but they didn't say that.......
 2003 Toreador Red/ Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, ( still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
pics
#43
SLAPS President and Webmaster
