Rear speakers in 04 Crew Cab - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 12-31-2007, 09:02 PM Thread Starter
I have a 04 F250 Crew Cab. The rear speakers are sitting right behind the back of the seat and don't put out a lot of sound. I just put Dynamat in the front doors and the quality of the sound is incredible (much better than before). Now the front speakers are overpowering the rears. I have seen people talking about installing speakers in the door where the ashtray is. Are there any other ways to put these in?
New truck
2008 F250 6.4L. Banks Six Gun with IQ, Banks CAI, Banks Monster filter back exhaust with DPF delete, AMP steps, 4" ProComp lift with 35s,
Old truck
2004 F250 6.0, 4" T-back MBRP, AFE Stage II/PG7, CFM+ Largemouth, Snow Stage II Meth injection, Pyro, Trans, Boost pillar mount, SCT running Extreme Street, ITP reg return, AirDog, Oilguard bypass, CCV mod, Diesel Site coolant filter, harpooned, 08 Diff cover, Daystar levelling kit, Viair onboard air with Siege train horns, heated mirror switch, Hella 500 Driving and Fog lights behind Billet grille, back-up lights, Kenwood 7019 in-dash DVD, Alpine S in the doors, 2 10" JL subs with Alpine amp.
ryano2121 is offline
post #2 of 6 (permalink) Old 12-31-2007, 09:21 PM
Lightningfast01's Avatar
Re: Rear speakers in 04 Crew Cab
I installed Infinity Reference 5x7's in my rear doors They have an aimable tweeter. They are plenty powerful.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
post #3 of 6 (permalink) Old 12-31-2007, 09:28 PM Thread Starter
Can you hear them better that the stock speakers? I have heard that Infinity's are too "bright" - do you agree?
New truck
Old truck
post #4 of 6 (permalink) Old 12-31-2007, 09:35 PM Thread Starter
I found Eurekaboy's write up on how he did this. He cut a hole in the bottom of the rear door panel and the door itself. Then he put in a speaker with a grill. http://www.eurekaboy.com/f250/doorspeaker.htm
I have Alpine S's in the front and like the way they sound. I found these http://www.alpine-usa.com/US-en/prod...model=SPS-13C2 that have a nice looking grill. Could I install these without them getting damaged with normal use of the truck? Or are there other speakers with more protective grill?
New truck
Old truck
post #5 of 6 (permalink) Old 12-31-2007, 09:46 PM
Speakers are a personal choice I recommend folks go to a good store and listen to their kind of music in the sound room before purchasing. I was surprised that the lower Reference series sounded better than their high line Kappa's to me. There was also a 300 dollar set of Focal's that sounded like pooh. The 1,200 dollar Focals did rock though. I have a full system so I can't say exactly. I have Infinity 6.5" components in the front doors with tweets on the dash and regular Reference speakers inthe rear door. Everything is driven by the amps 200 watt 4 channel which is 50 watts a piece. I think they are very clear without being to bright. Of course I have hearing damage from loud environments. I bought mine 3 years ago so the exact model has changed but these are close. I noticed the ref rear here is listed at 2 ohms That would sound twice as loud vs a stock 4 ohm speaker. Not sure if it would over work the stock radio or not...
fronts
http://www.infinitysystems.com/car/produ...y=US&Region=USA
rears
two 8" JL subs under the rear seat in a custom box.
http://mobile.jlaudio.com/products_s...p?series_id=22
post #6 of 6 (permalink) Old 01-02-2008, 11:54 PM
I don't like jicky looking grills but the door mounted speakers would sound better than the pillar. I might even try to mount the speaker in the door itself and make holes or cut lines like factory does with a router for the sound to come through. It would be more hidden and durable.
