Yes I did, take a look under the spare tire carrier, there you will find the wiring harness for the tail lights connects to the main harness of the truck. Apparently these connectors fail quite often due to dirt, moisture and a location that pretty much sucks. You can replace the connectors - or do what I did, just solder the wires together. I think the fuse is number 17 on the fuse block - if it isn't blown - the connectors are your likely culprit.
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
