Removing Plastic Fan Shrowd - Diesel Forum - TheDieselStop.com
Old 01-18-2010, 05:35 PM   #1 (permalink)
How do you remove the plastic Fan Shrowd?
Does just the top come off?
I am in the process of replacing my EGR and oil cooler and lacking details on how to remove all the parts.
Thank you in advance
-Jon Gage
Stock, New HPOP
Lots of car seats
JonGage is offline
Old 01-18-2010, 06:46 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
Need some particulars on your truck. From you mentioning EGR, it must be a 6.0L, but you should confirm that. On a 7.3L, the fan shroud is one piece, and the fan and upper radiator hose have to com off for it to be removed.
Hard or no-start? Check Here
klhansen is offline
