Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 04-15-2005, 11:19 AM   #1 (permalink)
Removing Rear View Mirror
Does anyone know how i can remove my rear view mirror mount. I am putting in an overhead pod and i need to move my mirror mount down about 2 inches. I tried using a heat gun on the windshield but that was a big mistake and crack the windshield. OOOPS. Does anyone have any ideas or know where i can take it to get this metal tab moved?
Any info will be appreciated. This is for my 99 f250 PSD.
99-F250 Quad Cab LB 4x4 - Banks 3.5" exhaust, AFE stage 2, DP Tuned and DP PCM , fuel tank mods, Tricumulator Spings,All gauges with Fuel pressure, Banks Big Head, Tru-cool,Turbo Lifesaver, Pioneer D-1, Viper 791, AirDog, Oil Guard Bypass.
w4racing is offline
Old 04-15-2005, 11:51 AM   #2 (permalink)
Re: Removing Rear View Mirror
Your local glass shop can move it for you. They do it everytime they change a windshield.
2003 F350 "TNT Ranch Edition" CC XLT DRW 4x4, X Springs, 6.0PSD, 6spd-ZF, manual hubs, 3.73's, 5.5" lift w/285 Dayton Timberlines, 2" DRW Spacers, 4" MBRP exhaust, 60/40 seats with lay flat mods, Arizona Beige with barbed wire pinstripes and custom acetoned badges, medium parchment int., and privacy glass.
<font color="red">My TNT Ranch Edition F350 4X4
<font color="blue">John's King Ranch Edition F350
<font color="purple">John's F350 4X4
<font color="orange">Bullwagons
<font color="green">Freightshaker Cabovers
Bullrack is offline
Old 04-15-2005, 01:27 PM   #3 (permalink)
The place that is redoing my windshield said that it comes standard the metal mount on the windshield. And they wont move it for me i guess i have to find another place to move down my mirror mount. GRRRRR. Thanks for the idea.
w4racing is offline
Old 04-15-2005, 02:20 PM   #4 (permalink)
Glass places around here said they wont guarantee no breakage... all i had to do was remove the mirror and apply heat to the remaining piece on the glass and easily pry it off. Parts stores have the glue to reinstall.
'00 F350 Lariat LE PSD - Auto - 2WD - CC - DRW - LWB - Autometer Triple Guages - AIS Intake - Juice w/Attitude - Edge Evolution - MBRP XP 4" Dual Exhaust
Rokcrler is offline
Old 04-15-2005, 04:04 PM   #5 (permalink)
My Photos: (21)
Did you play around with the pivots on the mirror? At first I thought I was going to need to move mine, then I noticed that the mirror can simply be pushed down and rotated. Here's a picture that show how mine ended up.
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 04-15-2005, 05:42 PM   #6 (permalink)
I have used a soldering iron to heat it slightly and then twist it off with some pliers. I haven't broke one yet but there is a first time for everything.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 04-15-2005, 09:00 PM   #7 (permalink)
snowdiver's Avatar
I just got one from a wrecker last week and I grabbed it and pulled it off the windshield with little effort.
1985 F-250 /4x4/C-6/200,000 miles/owner since 1990/
replaced injection pump twice, water pump twice, vacuum pump once, added manual glow plug button and electric fuel pump,new injectors at 197,000
snowdiver is offline
Old 04-15-2005, 09:05 PM   #8 (permalink)
[/ QUOTE ] Most of the time if you do this you will pull a chuck of glass out or crack the windshield.
FMT
Excursion Pics
Old 04-16-2005, 12:59 AM   #9 (permalink)
I twist them off all the time with a 15" cresant wrench. Only break about 1 in 20. Try to keep the wrench against the glass while you twist. Heat guns and torches will usualy cause cracks but try removing after truck has sat in the sun awile. If they hav'nt installed the glass yet have them get one for an excursion it's the same but the mirror bracket is about 2" lower.
2000 F350 Lariat CC LB
Superchips Tuner, Home Depot Intake W/K&N RE0870,MBRP Exhaust
rjsrs1 is offline
Old 04-16-2005, 01:18 AM   #10 (permalink)
Thanks guys for all the help. I got super lucky and the windshield they put on had a 2 inch lower mirror mount so my pod cleared the mirror. I guess on the 99 the mounts are higher because i had my mirror pushed all the way down and it cleared the pod but it was the metal mount that wouldnt allow the pod to slide by. Well its fixed finally and $200 dollars later hopefully i can get this cluster of wires straightened out so i can mount this pod. Thanks againg for the help.
w4racing is offline
