Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 11-03-2009, 12:31 PM   #1 (permalink)
Replacing brake pads
For someone who has never done it before, how hard is it to replace the brake pads? And if you replace one (only one is pretty thin), then should all four be replaced at the same time?
Also, do the rotors always need to be turned when pads are replaced? Mine are not perfectly smooth, but they don't seem too bad.
Thanks.
Scott
Early 99, 4WD
Skydiver is offline
Old 11-03-2009, 12:56 PM   #2 (permalink)
bryrylan's Avatar
My Photos: (11)
very easy, pull the wheel, caliper bolts(2), pulll the pads out put the new ones in put it all back togther. Dont forget to grease the slides so you dont get any sticking pads. I have done it with out turning the rotors but it eats pads faster plus, if your baseing this on looking threw the wheel the backside of the rotor maybe much more ugly than the outward facing side, this happend to me.
2002 F-250 3.5" leveling kit, 305-70-16 Procomp AT's,Eagle alloys 16" rims,Autometer procomp trans boost pyro gages, AIS, Coolat filter ELC, TS 6POS chip, Banks Billet torque converter, Transgo tugger shift kit, galaxy CB pumpin 20watts, Sirius radio,Kenwood cd player, kenwood door speakers, Infinity tweeters, 500 watt Pioneer amp, 10" Pioneer sub, Panelite LEDs, Custom back rack with LED lights, Bores guide poles, SHO-ME led warning lights, 4" exhaust, Grandrock 5" stack kit with bullhauler stacks,MBRP y pipe cover, 9Ft Fisher plow. Timbren SES
1995 30ft 14K Gooseneck flatbed.
10K winch
All LED lights
K&N filters suck end of story
bryrylan is offline
Old 11-03-2009, 02:48 PM   #3 (permalink)
doczenith1's Avatar
My Photos: (11)
I'm no expert but if you have one out of four surfaces worn excessively I would guess that the slide pins on that caliper are not functioning properly. I would replace all the pads and lubricate the slide pins. If you don't replace all of the pads you will most likely have different friction levels on each side of the vehicle which may cause the vehicle to pull to one side.
Perhaps Jack, the resident brake expert, will chime in and set the record straight.
Al
2002 F250SD Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. - added Silver Stars and SUVLights Harness, Pioneer Premier FH-P800BT deck, PRS-X220 amp and TS-W1240C sub, Pioneer GEX-P910XM XM Satellite Tuner, K&N FIPK, FM50 Delta Flow, 285/75R16 Bridgestone Dueler A/T REVO's. - 12/01
2003 Mustang Cobra, black convertible. - 6/07
doczenith1 is offline
