Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-07-2008, 04:20 PM   #1 (permalink)
Bacon104's Avatar
My Photos: (18)
Results on the only 7.3 competetor in Diesel Powers Diesel Challenge
Results of Diesel Power Challenge are in the Sept. issue and the only 7.3 truck fininshed 11 out of 12. Ernest said that he built the truck for lack of decent 7.3's out there and I tip my hat to him. The other Fords competing had a 6.0 or a Cummins.
Twisted his rear axle housing in the pull and got a DNF for that event but after posting 1,027 lb-tq to place 9 out of 12 for the dyno run.
My question is this:
The injection system has long been blamed for the 7.3 short cummins (get it?) but with big oil, including the Stealth Pump on the way, compound turbos, bigger injectors, tunes and everything else we can do...whats the deal? The 7.3's stroke is not as long as the 5.9's but neither is the Dmax's. I know that maybe Im just venting but I was really rootin for the 1 guy out of 12 who put in the effort to run a 7.3 in the challenge.
Truck:
Early 99 F-350 (99.5+Conversion)
Lariat Crew Cab Long Bed
05'-07' Front End/08' Tail Lights
184,000mi
Body:
8" Fabtech Lift
37" Toyo Open Country M/T
18" Rockstars
15" Cieling DVD
Engine:
99.5+ Conversion
AFE Stage 2 Intake
4" Turbo Back Exhaust
Ceramic Coated Bellowed Up-Pipes, Exhaust Manifolds, High Flow Turbo Outlet
ITP In-Tank/PRE-Pre-Pump Mod
HP Oil X-Over Line
AIH Delete
ISSPRO Boost, Pyrometer, Trans Temp A Pillar Gauges
CCV Mod
Truspeed
Other Rides:
67' Camaro RS/SS Dart Big M 540cu
Bacon104 is offline
Old 08-07-2008, 05:07 PM   #2 (permalink)
Supporting Member
missmanj's Avatar
ive always wondered but never really knew, what motor put out more horse and torque that is totally stock, the 6.0 or the 7.3?
2000 F250 7.3L 168,000
DP Tuner F5 Gauge Switch (Stock, High Idle, 40t, 80e, 140E, Lope Idle, 120R)
Rancho Nine Position RS9000XL Shocks
203* Thermostat
DIY Intake Napa 6637 Filter
CCV Mod
4" Straight Pipe Exhaust
ATS Turbo Housing
Powerslot Rotors & Hawk Pads
ISSPRO Gauges (Pryo, Trans, Boost, Water)
Turbo Saver
Max AC Assist
Stancor GPR
missmanj is offline
Old 08-07-2008, 06:08 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
According to Ford specs, the highest HP put out by a factory stock 7.3L was 275 - in the 2001-2003 7.3L with stick shift. Max HP with an automagic tranny was 250.
The first 6.0L in 2003 models put out 325 HP and 560 lb/ft torque. The last 6.0L in the 2007 models also put out 325 HP, but torque had been tweaked to 570.
SmokeyWren is offline
Old 08-14-2008, 10:21 PM   #4 (permalink)
Albie30's Avatar
Thats hp @ the crank,not the rear wheels
2000 F250 SB Crew Cab 4x4 Bfg 315s,DP tuner (live tuned)Edge juice ,Beans stage III hybrids,Turbonectics turbo,Snows water meth kit,Banks intercooler,Big head,triple disc torque converter,Power elbow Air Raid intake,Gibson 4" turbo back exhaust,203 thermostat,Suncoast tranny kit billet input shaft,Bts valve body,6.0 tranny cooler H11 Headstuds Pioneer Dvd and Nav, Sirrus satilite radio,New short block special thanks to Shawn @Ragin Diesel and Nate @Strictly Diesel
Albie30 is offline
Old 08-14-2008, 10:53 PM   #5 (permalink)
JimTJr's Avatar
My Photos: (6)
Yea,, it is. That is how the manufacturers always measure it,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 08-14-2008, 10:54 PM   #6 (permalink)
JimTJr's Avatar
My Photos: (6)
And yes, the 6.0 was designed to compete with the Dmax and Cummins for increased HP from the factory.
JimTJr is offline
Old 08-20-2008, 12:56 PM   #7 (permalink)
Justin C.'s Avatar
I talked at length with Bean about this, and while he said the new Stage 3 stealth pump will run as large of an injector as you want, the problem was that the HEUI system was still too slow. He said you can't get the fuel out of the injector quick enough, and that would be the big limitation now that the big oil problems seem to be solved.
Justin
Visit the Middle Tennessee Pullers Association at http://www.midtnpullers.com
1997 F-250 Power Stroke - 200k
Bean's Stage II's
DP F-6 Tuner
Tymar Intake
Southbend Con OFE
Grand Rock 5" Stacks
2005 F-350 Power Stroke (company work truck) - 150k
ARP Studs
EGR Delete
Justin C. is offline
