Reverse warning system
Hi Guys!
It has been some time since I've posted. Glad to be back!
I have a question about my reverse warning system on the F-350 in my singnature.
About a month ago, I was pulling my trailer (16 ft. utility trailer) behind the truck and I backed it into the garage. I pushed the "off" button on the dashboard and the reverse warning system stopped beeping, and the "off" light came on.
Then about two days later, I was backing into a parking space at work and the system didn't work. I tried pushing the "off" button but the light goes off just for a fraction of a second, then comes back on.
I read the owner's manual and it states that the truck must be in reverse and the ignition key "on" before the system will change modes. It was in reverse and the key was on both times I operated it.
Now, the "off" light is still on and the system won't work. What is wrong with it, and how can I fix it?
Thanks for your replys in advance. Craig.
2005 F-350 Superduty, 4X4, 6.0 diesel, sc, srw, lariat, B&W Turnover hitch, tow command, red.
2005 Excursion Eddie Bauer, 4X4, 6.0 diesel, 2nd row buckets, all the bells and whistles, Ford 30mm rear anti-sway bar, true blue/arizona beige.
