running lights, rears working fronts not?
Hey guys, need a little help. I did a trans replacement last weekend and now I have a funky problem. Had no running lights or dash lights, replaced #17 fuse and got my rear running lights and dash lights but no front running lights? I thought fronts and rears are all on the same circut???? Now, I can tell you that we were inside the drivers side engine compartment also because I did the up pipe doughnuts at the same time I did the trans, (made it much easier) so we were crawling around that area. other than that, not sure which direction to look.
any help would be appreciated.
thanks,
E
Big E and family of Three
2002 F250 4X4 CREW CAB PSD 4" LIFT
4" turbo back exhaust*custom tymar*DP tunes*Polished ATS housing*6.0 intercooler*Chromed intercooler pipes*DC Power Inc. 190 amp
Alternator*Dieselsite boots*203 thermostat*40K Trucool*tugger kit*tripple TC*Manual TC lock-up*EBPV brake*AIH delete*boost Annihilator*Custom CCV*ITP/KCM (HPX)*Coolant filter*08 diff cover*DI fuel shim kit .055 @68 psi*engine mounted fuel gauge*custom engine cover*triple gauge*((XM))
2004 Keystone Sprinter 297fwbhs 5th wheel
with most of the goodies
