Seat Belt Slow To Retract - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 01-29-2008, 01:54 PM Thread Starter
AllOutFirefighter13's Avatar
Question Seat Belt Slow To Retract
I'm having a small problem with the truck listed in my sig. with regards to the driver's side seat belt retraction system. Being as I have the extended cab, I have the retractor system located inside the seat. The system works fine when I'm putting the seat belt on and provides holding when needed (bumpy terrain, hard braking, etc.), but when I take it off, it just doesn't care about going back in. There seems to be a little tension...enough to "try" and pull it back in, but I always have to help it until the belt is all the way back in. It's almost like the spring went weak overnight.
I took off the plastic cover on the top of the seat (just behind the left shoulder of the driver), and that's when I found out that the actuall spool seems to be located lower in the seat. I cannot find a way to get in there to see what happened, but I'm hard-pressed to believe that I'd have to buy a new seat to get the seat belt to work. Does anyone have any ideas on what I can do to restore the functionality of the seat belt?
TIA,
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
post #2 of 24 (permalink) Old 01-29-2008, 07:44 PM
locknload223's Avatar
Me too, curious to see a fix.
'00 Excursion Limited- 4" lift, Vcodes/F350 block, 315/75/16's, airbags, ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80tow, Drive-Thru, 80econo, 120race, 4" MBRP, 6637, 6.0 I/C, AIH delete, Foil delete, Auto Enginuity .
locknload223 is offline
post #3 of 24 (permalink) Old 01-29-2008, 08:15 PM
High PSI's Avatar
My Photos: (18)
My pillar mounted belt is the same way!
'02 Black F350srw,Lariat,CC,SB,OR. - BTS TRANS,Coated 1.00 BB TN-non EBP-6.0 Spearco IC-DP Tunes(stock,HI,60T,80E,120R)MAP maximizer-ITP reg ret.-AirDog-Fluidampr-BWD coated/ bellowed pipes-AFE2-4" Magnaflow-Dieselsite coolant filter&ESOF SS lines-Billet/203*stat-Fleetrite ELC-Bilsteins-Hawks&Cryo's-Centramatic-Billet-Extang-Husky box-Husky Liner-EGR-LineX-Alpine-Kicker-PIAA-Dynamat-Sirius-Viper-ES Poly's-BFG 315/75/16 AT's-DTS 4.56LS-31 row 6.0 Cooler-UltraLite trans,pyro,boost-DiPricol fuel-PML pan-Mag-Hytec cover-Powerslot-Hawk. Marinco,Snowman,Harpoon,AIH,CCV,foil,door ding,console mods.
High PSI is offline
post #4 of 24 (permalink) Old 01-29-2008, 09:43 PM
My Photos: (19)
I too have this problem!
I'm starting to wonder if we all have this issue and we are all waiting for someone else to fix it first! Oh well. It's too cold outside for me to tear into my seat. Sorry.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #5 of 24 (permalink) Old 01-29-2008, 09:49 PM
YA, I've got the same problem with my 2001 PSD F250. Wonder if this is a safety problem that should be taken care of with a recall. How do you contact National Safety board?
Blue Beast, 2001, F250, 7.3 PSD, AFE Stage II, Autometer Pyro & Tranny, NAPA 4071 Coolant filter, Rancho 5000 damper, Toyo 325-85-16, Lund window shields, Arrow cap, DP Tuner 40-60-80.
micapeak is offline
post #6 of 24 (permalink) Old 01-30-2008, 05:48 AM
I say we all just show up at Mr. Ford's front door with our arms crossed and tapping our feet.
post #7 of 24 (permalink) Old 01-30-2008, 09:04 AM
crowz's Avatar
Ive got a few vehicles including my 2002 F250 that does the same thing. Im kind of scared to fix them though to tell you the truth.
Reason being that you cant tell you have the seat belt on once they get lazy about retracting. Im afraid if I "fix" it back to retracting good it would anoy me by pulling to much while driving. Course I dont know what the truck was like new so I dont know if it was bad about pulling to much. My 98 gmc I traded in on the F250 was anoying and I had ended up adding one of those clips to the seat belt to keep it from pulling on my neck while driving.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 280,000 miles.
Rotella 15w40, 295/75R16 Nitto Terra Grapplers
EBPV disabled
crowz is offline
post #8 of 24 (permalink) Old 01-30-2008, 09:19 AM
fxdwgi's Avatar
The 'fix' for this from Ford is to attach 2 felt lined stcikers to the d-ring of the belt. It is supposed to reduce the friction. We have seen some work, others don't
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
post #9 of 24 (permalink) Old 01-30-2008, 09:51 AM
jdc753's Avatar
My Photos: (31)
Send a message via AIM to jdc753
I got the same problem as well with my 05 crew cab. I was thinking it was more of a twisting thing getting hung up but its definitely seems to be a week retract spring or something. Gotta give it a little help to retract back all the way. Least it doesn't hang out enough to get stuck in the door, then I would start to get really annoyed.
86 Ford F250 4x4 with 4in Rough Country lift and poly bushings all around converted from 351W to 6.9L Diesel (rolling chassis at the moment)
05 F350
jdc753 is offline
post #10 of 24 (permalink) Old 01-30-2008, 12:04 PM Thread Starter
I guess maybe that I use the driver's side more than the passenger's side is one reason why the driver's side is weak. The passenger's side works like new. When I get around to it and if no one has replied yet for a fix by taking apart the seat and finding the cause, I'll see what I can find out and post my findings.
Later,
Joey
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
post #11 of 24 (permalink) Old 01-30-2008, 12:40 PM
Samuel1941's Avatar
Lightbulb
A check of the Warranty guide for my 2005 states that the safety restraints (seat belts) have a 5 year/ 50,000 mile warranty.
This may be of help to those of you who have newer trucks............
1993 F350 XLT DRW (sold)
2000 F350 XLT DRW (sold)
2005 F350 Lariat DRW (traded in on new truck)
2012 F350 Lariat 6.7L SRW SuperCab all the bells and whistles
Purchased thru Bobby Williams, Sunrise Ford, Fontana, CA
Samuel1941 is offline
post #12 of 24 (permalink) Old 01-30-2008, 02:31 PM
High PSI's Avatar
My Photos: (18)
You would think a lifetime warranty on safety restraints,since a lawsuit for faulty equipment would be very easy to ensue.
High PSI is offline
post #13 of 24 (permalink) Old 01-30-2008, 08:20 PM
My Photos: (19)
I was thinking about this today. Remembering what someone mentioned that the retractor is actually in the bottom of the seat, and looking at the hinge mech. in the seat, it's really dirty in there. Spending as much time as I do in the driver's seat with the belt retracted, if all that dust and dirt gets into the spring causing too much friction between the layers of the spring. Thus, poor retraction. I think all it would need is a good cleaning and re-lubing.
... If we could get to the mechanism.
BTBBT is offline
post #14 of 24 (permalink) Old 01-31-2008, 12:31 PM Thread Starter
Tech Tips Appreciated Very Much
Originally Posted by BTBBT View Post
...If we could get to the mechanism.
Yea, I'm gonna try and get to the mechanism, but that may prove troublesome in itself. I also thought about the dirt and that is a possibility on my truck.
I sure wish a techincian or anyone that has tackled this type of job before could chime in and give some tips/tricks on getting to this sucker. Knowing me, I'll have the whole seat out before I get it fixed! Oh well....
Later,
Joey
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
post #15 of 24 (permalink) Old 01-31-2008, 05:20 PM
KF6ZVT's Avatar
On mine the retractor is in the seat back. I've had the seat apart twice and cannot determine a fix for the slow retraction. The retractor itself has more than enough pull, and there are no obstructions or any wear in the plastic guide at the top of the seat. Everything looks like it should be good to go.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
KF6ZVT is offline
Similar Threads
slow seat belt retraction vetterestorer 1999-2007 General Questions 3 05-18-2007 11:04 AM
Slow retracting seat belts marinegunner 1999-2007 General Questions 2 02-28-2007 01:25 AM
Seat Belt droptine Power Strokes 1994-1997 General 2 03-01-2006 01:16 PM
Seat Belt MX723 6.0L Power Stroke Engine and Drivetrain 0 07-30-2005 12:34 AM
Seat belt chime, not the "belt minder" thing. AJ'sDad Power Stroke Excursions 6 04-12-2001 03:07 PM
