Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 08-23-2006, 03:28 PM   #1 (permalink)
NCHornet's Avatar
Servicing transfer case ?
I know it uses ATF but should it be synthetic? I haven't looked but I assume there are two plugs one for fill and one for drain? Are they a allen bolt or will the square end of a ratchet work? What is the capacity?What is the service interval. I have 51K and I don't believe it has ever been done, at least I know I haven't since 21K was on the clock. Anything special I should know?
Kevin
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 08-23-2006, 04:08 PM   #2 (permalink)
Re: Servicing transfer case ?
I jsut did both of mine a couple of weeks ago. You will need a 10 mm hex drive socket. I picked one up at Autozone for like &6. There are two plugs, a fill and a drain. Make sure you can get the fill plug out before you drain the oil. I used synthetic Royal Purple myself. I do not think it is required but I figured it could not hurt. You should need two quarts.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 08-24-2006, 10:26 AM   #3 (permalink)
I had my transfer case serviced in May when Brian installed my BTS transmission. Since it was out of the truck, they drained it and put in Schaeffer's transmission fluid that they use in the BTS transmissions. It's a synthetic blend. Here's the web site link. http://www.schaefferoil.com/204_transmission_fluid.html
2008 F350, 6.4, XLT, Forest Green, SRW, CC, 4x4, Longbed, 6-speed, Manual 4x4, Camper Package, Plow Option, SIRIUS Sat Radio,
Early 99, F250, 7.3, XLT, White, CC, 4x4, Short Bed, 285x75x16 BFG AT, Ford AIS air filter, Warn Transformer Grill Guard, BTS Trans by Brian T. 176K miles and still going.
1abnengr2 is offline
Old 08-25-2006, 08:05 AM   #4 (permalink)
NCHornet's Avatar
Thanks y'all, but why do you need to remove the fill plug before draining the oil?
White Stroker
NCHornet is offline
Old 08-25-2006, 11:13 AM   #5 (permalink)
Just to make sure you can refill the transfer case, sometimes the plug can get frozen. Happened to me.
Rusty
2000 F250 CC,SB XLT 4x4,120,000 miles,FP-135A, 2005 5.9 Cummins HPCR,Rokktech crank sensor,ZF6,Transferflow,Magnaflow, Mag-hytec diff,Auburn limited slip,Dynatrac hub replacements....Sold........
http://community.webshots.com/user/rusty1161
rusty1161 is offline
Old 08-25-2006, 04:00 PM   #6 (permalink)
NCHornet's Avatar
OK, I went and bought the 10mm allen socket so hopefully it won't be glued or welded in.
White Stroker
NCHornet is offline
Old 08-25-2006, 06:27 PM   #7 (permalink)
I'm going to add one more thing (besides taking the fill plug out before draining it). Do not use an air wrench on these plugs and don't overtighten them. They are tapered and they will crack the case if you overtighten them.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 08-25-2006, 08:29 PM   #8 (permalink)
lol I would never think of using air tools there anyways haha...
2001 F250 Platinum Edition
Hybrids, 38R, Studs, Springs, Forged, etc...
12 second crew cab
Maintain is offline
Old 08-26-2006, 06:58 AM   #9 (permalink)
NCHornet's Avatar
Did the fluid change last night. Used the new Mobil one synthetic stuff. I put two quarts in but none ran out. I can bend the end of my finger and hit fluid like on a diff.Is this enough fluid or should I get another quart and fill until she runs out?
I think this was the first time it had been changes, 7 years /52K it was pretty black. How often should this be done?
White Stroker
NCHornet is offline
Old 08-26-2006, 08:40 AM   #10 (permalink)
I change it every 30k miles or 15K miles if I use 4wd a lot. It's just 2 quarts +/- so it's a cheap change. Yea, if it wasn't completely full I'd add a little more just for giggles.
Joe
