Sharp turns while in 4WD? Truck rocks! - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 02-18-2006, 08:59 PM Thread Starter
I was trying to get out of an icy parking lot today and was going nowhere in 2WD. So, I switched to 4WD and when I was making a turn, the truck felt like it was driving off a small step or something. Very noticeable! It was a sharp turn, but not turned all the way. Is this normal or is there something wrong? Thanks! Matt
2002 F-250 Lariat C/C 4x4
7.3L Powerstroke diesel
KC10Chief is offline
post #2 of 12 (permalink) Old 02-18-2006, 09:11 PM
RSP
My Photos: (17)
Re: Sharp turns while in 4WD? Truck rocks!
Its normal, If you were turning sharp Left then the right front Tire would Side slip making it feel like it fell, Same way if you were turning right the Left tire would side slip. I plow Snow and I feel what you describe all the time.
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection
RSP is offline
post #3 of 12 (permalink) Old 02-18-2006, 09:19 PM
My Photos: (10)
front u-joints are binding-mine does the same thing, I was told its normal. Mike
BRIGHT RED Early 99' PSD Crew Cab Longbox F-250:
PERFORMANCE
-pmt late computer
-Dp 6 position chip (stock, tow, 80, 120, 140 xtreme, high idle)
-Factory Tech Monster Box
-ARP headstuds
-Garrett Gtp38r with 1.15 exhaust housing and no wastegate or ebv
-4" stainless mbrp exhaust w/6" tip
-Tymar intake
-stealth dual 17* hpops with dual IPR's
-bds 238cc a codes
-regulated return fuel system
-Triple gauge pod
-dahl 150 seperator
OTHER
-8" Pro-comp/shackle lift, 6 shocks up front, 4 in the rear
-dual steering stabilizers
-37" M/T Baja Claw radials on 16x12 M/T wheels
-carr hoops steps for each door
-2 mtx subs, mobile a/v system
-15 percent tint all around
-complete 2006 chrome package front grille, bumper, lights, and badges.
-bull bar
-chrome handles/mirror covers/tailight guards
AWAITING INSTALL:
Hopefully an intercooler and some methanol once I get this thing going....
charkly is offline
post #4 of 12 (permalink) Old 02-18-2006, 09:32 PM Thread Starter
Can it damage something from doing that a lot? Matt
post #5 of 12 (permalink) Old 02-18-2006, 09:48 PM
if it was the front u joints then it would do it when not under power right? not just when in 4 wheel drive
2003 7.3 250 cc 4x4 mbrp turbo back, DP tune, gauges, (BB, OIL still waiting for install) traded for higher education
new transportation 2004 wrx stock but the 30mpg is great
[censored].com/
sdymn518 is offline
post #6 of 12 (permalink) Old 02-18-2006, 10:54 PM
its the result of a LOCKING Diff...the front wheels
are locked together and can not turn at uneven
speeds (as they do when the front diff is open
or unlocked)
bushpilot is offline
post #7 of 12 (permalink) Old 02-19-2006, 07:28 AM
What is happening is you have all the wheels locked up through the 4X4 and they all want to rotate at different rates. E.G different turning circles.On a loose surface the tyres can slip a little but on hard grippy surface the tyre winds up and distorts until it lets the grip go.Short wheelbase vehicles have less of a problem than our long wheelbase.
It does load up the drive components and should be considered when ever 4X4 is engaged.
Ron
2000 F350 king cab 4x4,No engine mods,Roo Bar,Headlight and bonnet stone protectors,Inlet snorkel,flares on front,Engine driven air compressor and receiver,Hot water tap,tyre temp and pressure monitor,95 ltr fuel tank under right hand side,aluninium side steps,flat trayback,50ltr water tank under left hand side,heavy wired front and back for 4500lb electric winch, Bilnstien shocks,converted to right hand drive,battery conditioner,electric trailer brakes,heavy duty tow bar,synthetic oil in tranny,extra tranny coolerand filter ,tranny temp & pyro,
Ride-Rite airbags all round.Full flow muffler outlet at rear of vehicle.Engine breather mod.HHO generator
knapp is offline
post #8 of 12 (permalink) Old 02-19-2006, 12:00 PM
Ron
[/ QUOTE ].Thanks Knapp. I have experienced this too. I try to engage my 4X4 once a month to keep everything working, on dirt roads or on paved only if it's raining as the water will act as a lubricant for the tires.
If you can read this, thank a teacher, THANK A VET. it's in English: 04/04 F350 Sold.
SAVAGESAM is offline
post #9 of 12 (permalink) Old 02-19-2006, 12:19 PM
olddieseldude's Avatar
My Photos: (16)
or unlocked)
I thought I'd read in previous postings that there is no OEM locking front differential in the Super Duty trucks. Am I wrong?
(Edited to put my response in context)
RickN
(mods listed in comments under photo in above link)
olddieseldude is offline
post #10 of 12 (permalink) Old 02-19-2006, 12:36 PM
JimTJr's Avatar
My Photos: (20)
[/ QUOTE ] Not locking differentials, it is a 4x4 thing,, no matter what brand. Like they mentioned above. Each front tire is traveling a different distance in a turn. So one "Binds" some and when it releases grip it will "Jump" for no better term to use.
COMPLETELY normal. DO NOT engage 4x4 on DRY PAVEMENT,, only dirt, wet or ice/snow. Other wise it CAN damage things if done often and harshly!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #11 of 12 (permalink) Old 02-19-2006, 01:00 PM
Only time I would use it on hard pavement like surface, is if you need traction and are driving in a straight direction. I wouldn't use it on Ice driving at any speed other then when your stuck.
04,F250,PSD,Built 01/04,4X4,CC,LWB,Dipricol Gauges, Muffler Delete,A.I.C. Mod,Etrex Legend GPS,Sirius Satellite Radio ,Firestone Airbags,,Prodigy controller,16k Power All 5th Wheel
05 LE3305 Weekend Warrior 5er,Suzuki camo 500 Vinson,Suzuki Ltz 250,
Buszz is offline
post #12 of 12 (permalink) Old 02-19-2006, 05:34 PM
JimmyDee's Avatar
My Photos: (24)
You are correct. Probably wouldn't want it on everyday use truck. one front tire grabbing on dry road and the other one on ice will cause the truck to turn hard.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod;
, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in
AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
