Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > General Questions
General Questions General questions related to 1999-2007 Super Duty trucks. If it doesn't fit the other categories, post it here. Gas engine discussion that pertains to all models is allowed. Specific gas engine questions should use the Gas Engines forum.
Old 01-28-2009, 12:39 PM   #1 (permalink)
Simple disabling PSD. Changing Ing. Cylinder
Somebody tried to steal my 01 PSD 7.3
They jimmied the door and busted the ignition cylinder. Does anyone know how to change the ignition cyl. I took it out once to do the dinger delete but Im sure I had to put it in neutral. With the busted cyl I cant unlock the key to put it in neutral now. How do I get around this.
Also, is there a easy way to kill my superduty so no one steal it once its fixed. I would usually just pull the distibuter cap wire (in my stang)but not so easy on a diesel. ( I pulled both batteries in the mean time )
It really pisses me off. I've spent so much on it and someone is messing with all my hard work. On the up side I had a chance to pull my computer and send it to DP.
Any help would be great
P.J.
sohip is offline
Old 01-28-2009, 12:54 PM   #2 (permalink)
klhansen's Avatar
My Photos: (107)
You could just pull the PCM power relay and take it with you. It isn't going to start without a working PCM.
Also there's a replacement relay that works with a key fob or cig lighter plug-in available from Cyclops that would do essentially the same thing. The relay doesn't work without either the fob or plug-in in place.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 01-29-2009, 12:52 AM   #3 (permalink)
Yeah, thats the kind of idea I was looking for.... I only occasionally use my PSD in the cold winter days. I'll totally do that. At least it'll be there when I need it
sohip is offline
Old 01-29-2009, 09:06 AM   #4 (permalink)
P.J.
There is no way to get it out without turning it with a key or otherwise having to drill it out and then turn it with a screwdriver or similar tool.
early 99 F350 4x4 wth some upgrades
DieselDeaf is offline
Old 01-29-2009, 09:04 PM   #5 (permalink)
Thats what I kinda figured...otherwise one dude with a superduty could pretty much rip off anyone elses truck
I also gotta look into those jimmie jammer plates to put behind my handles.
Maybe a good 2 way alarm on silient and louisville slugger could help
sohip is offline
Old 02-02-2009, 09:04 PM   #6 (permalink)
Tie that 2 way alarm in with a gps tracking system and it can send you txt msgs when the alarm is going off. Also allows for shutting the truck down remotely.
I would love to see the look on someone's face when my junk goes to idle while they are going down the road and they cannot drive it anymore.
2002 F-250 Crew Cab Long bed 7.3 4x4. Edge w/attitude, Edge Evolution, Triple disk converter, whicked wheel, 203 t-stat, High pressure bypass, BTM, lifted sitting on 35's. Onboard Air, tank, train horns, air bags w/ controller. Custom 86gal AUX tank, Tonneau cover, Dual Din in-dash DVD/NAV.
02Boathauler is offline
Old 02-07-2009, 07:23 PM   #7 (permalink)
I was actually able to get the ignition turning with a screw driver. It would have been long gone if my batteries werent frozen solid... It happened my DP computer came ... This thing is a monster ....
Anyway, my deductable is 500 bucks how hard is to change the door handle. the ignition should be easy now that it turns. Any idea ??
sohip is offline
Old 03-10-2009, 01:31 AM   #8 (permalink)
This is just an idea that I've recently thought of. I don't know how good of an idea it is though. I was thinking of mounting a remote toggle switch somewhere out of sight, where only you or other operators of the truck know where it is. This switch could be used to bypass the brake-interlock switch that allows the truck to be taken out of park upon someone stepping on the brake. So my whole theory is to be able to flip the switch off when exiting the truck, so if someone else gets in the truck, manages to get to the point of being able to get it running, they won't be able to remove it from park. Granted, this would all depend on the strength of the system that retains the shift lever in the park position, of which I really am not familiar with. So someone chime in and tell me why this really isn't a good idea. I know someone will know better. It was just my bright idea of the day. =)
2003 RED F-250 Lariat FX4
SC/SB
6.0/TS
Chrome Steps
4/4/09 92k and counting!
My Additions:
Fast Idle Mod, Manual Engine Fan Control Mod,Cab Marker Lights, Smoke Ventvisors, Chrome Fender Trim, Weatherguard Diamondplate Saddle Tool Box, Diamondplate Tailgate Guard, Diamondplate mud flaps, Rhino-Lining, Kenwood AM/FM/CD, Garmin Nuvi 350 GPS, Access toolbox-to-tailgate tonneau cover, Cobra CB/Wilson 2000, Toolbox mounted trucker antenna, MagLite Rechargeable Flashlight, Fire Extinguisher
Keep on truckin
andrewbalser is offline
Old 03-10-2009, 03:51 PM   #9 (permalink)
Or, what about wiring a hidden toggle switch to the starter solenoid to switch if off when you're not in the truck. Seems that this would keep the truck from even getting started. just my .02 cents worth
short-stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 03-11-2009, 10:34 PM   #10 (permalink)
^^ You mean something like this?
Great idea! Racing ignition switch is really cool! It's the same as what they have in race cars right?
alternator auto parts
thomatt12 is offline
Old 03-12-2009, 04:31 PM   #11 (permalink)
Tallavana's Avatar
My Photos: (14)
Dont know if Im supposed to say this or not but patrol cars have the shifter lock taken off the brake pedal and rewired to a foot switch that is hidden under the carpet. In order to put the car in gear you have to know where to press your foot on the floor.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
2002 F250 Lariat 4x4 Crewcab PSD Shadow Grey/Black
BD X-Monitor, BD Pressure-Loc, SCMT(80),AFE Magnum, 2.5"leveling and 4" block, Bilsteins, Retrax, LineX, Oilguard, MBRP 4" SS, Moto Metal 950 18x9, Toyo A/T 325/60/18, 05 front end w/Harleys, KC 05 light kit w/3 driving lights.
Tallavana is offline
Old 03-13-2009, 02:34 PM   #12 (permalink)
kench's Avatar
Not in any MP car that I've driven, but good idea.
2001 F-350, 7.3L, Crew Cab, 4x4, Dually.
It likes to pull a 28' 2005 KZ Frontier Travel Trailer (8,000#).
Located on Long Island, NY
kench is offline
